Help! After inverter assembly change my car dont start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Attila Aranyi, Dec 8, 2018.
  1. Attila Aranyi
    Attila Aranyi New Member
    Hungary
    I need some help. I have a 2007' Prius Gen2. Usually I have been repairing in the last seven years. Four weeks ago the inverter went awry. Yesterday I changed it, but the car didn't start. The Techstream didn't found any trouble code, but the slip indicator, ABS, and the check engine light on, when I push the brake pedal + power button. And nothing happens, the engine not starting. What could be the problem? Any idea how can I solve it?
  2. Patrick Wong
    18,200
    6,472
    1. Make sure the orange traction battery interlock is correctly inserted, the lever pivoted 90 degrees, then slid down to lock in place.
    2. There must be diagnostic trouble codes logged with the warning lights on. You'll need to figure out why your version of Techstream is not retrieving those DTC.
    Barry CLEMENTS likes this.
  3. Attila Aranyi
    Hungary
    Thanks, I will check it, but now I give up for a few days.... :)
  4. bisco
    49,387
    always smart to walk away, and live to fight another day
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Did your 12 volt battery go dead because you left the doors open for days? Turn on the headlights see if there nice and bright.
  6. Attila Aranyi
    Hungary
    Thank you for your tips, but the first was the winner ! :) Today I rechecked the connections, and it works fine! Thank you for your help! Have a nice day! (I have)
