Does anyone have experience with Greenlots?
Discussion in 'Prime Plug-in Charging' started by TonyPSchaefer, Jul 18, 2017.
  1. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I found out that the chargers put in at work were done in partnership with Greenlots.
    They have an app and their website makes broad statements with marketing speak. Does anyone have any real experience with them?
  2. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Will there be a cost? My rough estimate (with gas at about $3) is a Prime full charge is worth about a buck.
    Data Daedalus and Prius from Dad like this.
  3. TonyPSchaefer
    14,816
    2,501
    66
    Facilities here on campus don't even know. The head guy said perhaps it would be free at first and then, once they've got things figured out, they might start charging just for the cost of electricity. That's when I mentioned charging costs compared to gasoline costs, much like you indicated.
    I found out this morning that I seem to be the first person on campus with a plug-in vehicle (and I don't even have it yet). I'll be trailblazing the path it seems.
  4. Ascegan
    Ascegan Junior Member
    edison, nj
    Greenlots app and charger is very clunky, like beta version of ChargePoint. We have Greenlots and ChargePoint and I use the Greenlots only if the ChargePoint are full.
    • The app can’t remember chargers so you have to scan a barcode on the charger stand every time.
    • Even then, it prompts you to choose which cable you will use- but the cables are not labeled, so you have to guess which one to plug into your car.
    • Even if you try to “favorite” the charger in the app it forgets ever time.
    No updates about charging from the app- history, locations, charging time...It’s like the app was a high school science project.
  5. Ascegan
    edison, nj
    PS. My company just installed the chargers and the #1 issue is getting pickup truck & SUV drivers not to take up the spaces.
  6. padroo
    padroo Senior Member
    2,763
    2,252
    They need to treat these like handicap parking along with a fine. Just to get their attention.:whistle:
    Ascegan likes this.
  7. bisco
    52,066
    always the number one problem
  8. Ascegan
    edison, nj
  9. bisco
    52,066
    el dobro just posted an article: it is now illegal to park a non plug in vehicle in a plug in spot in illinois. private or public, violators will be towed.
    let's hope it starts catching on
    markabele and padroo like this.
  10. Tideland Prius
    16,563
    Also ChargePoint and GreenLots signed an agreement to roam on each other’s networks.
    So right now, if you have a ChargePoint account, you can roam on FLO (Canada) and GreenLots
  11. LilyHere
    LilyHere Junior Member
    48
    2019 Prius Prime
    One hundred percent justified and called for!
