3rd Party Catalytic Converter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Old Wolf, Dec 14, 2018.
  1. The Old Wolf
    The Old Wolf Junior Member
    Payson, Utah
    My 2007 Prius has been throwing a P0420 for some time, so I'm not surprised the cat needs to be replaced. Toyota wants $2500 for the job. Meineke is around $700.00.
    But I can find multiple websites that advertise "2004-2009 Toyota Prius 1.5L Catalytic Converter Direct Fit" for around $104 to $116.00.
    Are these worth anything? Are they Chinese garbage? Or will they do the job just fine and the other shops are just charging ten prices for the same kind of thing?
    Thanks for your time!
  2. Mendel Leisk
    41,296
    Prodigyplace likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Since you’re not in CA or NY, they could work.
    Just depends on how long you want the fix to last.
    SFO likes this.
  4. The Old Wolf
    Payson, Utah
    I will do just that, thanks for your input! :)
    Raytheeagle likes this.
  5. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    I did this with the help of a welder in CA for $300 IMG_6424.jpg the four bolts are easy enough to remove and take the center section of exhaust in to your favorite welder to splice in the replacement. IMG_6388.jpg
    iPhone ?
  6. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    That would never pass in Cali. But will probably work fine. Cost for cats is directly related to the amount of exotic metals in the catalyst. The one you got is a generic one size fits many. A 420 code does not necessarily mean the cat is bad, btw. It also does not equal the "go private" price of a share of Tesla.
  7. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    This explain the big price difference of OEM vs aftermarket. And why I remember someone's universal fit only lasting a year.
    Warranty is the other equation too. CARB certified catalytic converters require testing to prove that they are as effective as OEM, thus being certified as CARB compliant. AND, aftermarket catalytic converters must have a MINIMUM warranty of 5yr/50,000miles. Aftermarket ones only seem to have a 1yr warranty.
    Thus the price difference in catalytic converters. Low cost = shorter longevity due to less precious metals, and no testing certification.
  8. exstudent
    2,214
    905
    Torrance, CA
    BTW, if the engine is burning A LOT of oil, this will kill all catalytic converters, quickly.
  9. Paul Schenck
    523
    306
    Fresno, California
    This one is specifically Cali approved. It does fix the problem and actually has more platinum coated ceramic in it than the originals. The OEM is the entire mid section $1900. Which includes an additional cat converter past the second O2 sensor.
    iPhone ?
  10. oil_burner
    oil_burner Active Member
    249
    126
    I bought the cheap Ebay version for $100, you have to cut your exhaust just past the 2nd cat and bolt it on. It turned off the CEL for me and I really don't expect it to last for the price how much platinum in the cells could you expect once you factor in the cost of the pipe, hardware, welding, etc. But my car burns a lot of oil so once this cat becomes clogged at least I can take it off the car and punch the honeycomb out and let the exhaust free flow.
  11. The Old Wolf
    Payson, Utah
    The deed is done, I scored a direct fit cat from Arctic Exhaust on eBay for $104, my local mechanic installed it for $167. A lot cheaper than the $2600 Toyota wanted, cleared my code, and will last long enough for my needs. No emissions tests up here in Maine. Thanks for all the input!
  12. Briana Giselle Jauregui
    Briana Giselle Jauregui Junior Member
    South Pasadena, CA
    THANK YOU!
    Our battery light came on and mechanic said it was the cat.
    Gas had been flying out of here (Prius 07) super crazy fast.
    The drives were a bit crazy though. Very hilly and the area's residents drive so fast you must keep up. I thought maybe that was why.
    Though for a few months now when turning car on I experienced an odor. Fumes of some sort. A few times there was splatter from exhaust of which the mechanic was aware.
    I'm thinking maybe I could do with another mechanic?
    Anyways, I'm in California.
    Thanks for all the info y'all.
