Why Mileage Gets Worse in the Winter
Discussion in 'Gen 2 Prius Fuel Economy' started by TonyPSchaefer, Oct 30, 2011.
  1. William Slattery
    William Slattery New Member
    Maryland
    I have 2004 prius with 300k+ and it went from50mpg to40 in one week any ideas no mil light
  2. VFerdman
    VFerdman Senior Member
    1,148
    1,171
    Western Massachusetts
    Are you a new owner of this vehicle? If so, that's probably winter drop due to different fuel mix, colder temps, etc. If you have owned this car for more than one summer->winter transition and this drop is unusual, then at 14 years old and the mileage, I would say start thinking about the traction battery.
    NortTexSalv04Prius likes this.
  3. William Slattery
    Maryland
    I've had car for 5 yrs no trouble runs fine battery gauge shows battery cgarging fine runs fine in all electric up to about 25mph then engine kicks in no pinging air filter new spark plugs new oil new tires new only time it did this before air filter clogged
    #43 William Slattery, Nov 6, 2018
  4. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    114
    FYI
    A couple of thoughts and suggestions
    First on Gen2 and many vehicles ambient temperatures has a noticeable impact on miles per gallon and fuel consumption... winter will for sure drop mpg
    to mitigate some fuel pump pain
    purchase a SG2 from autozone
    winterize vehicle
    purchase oem block insert heater and oil pan heater
    plan your trips for warmest part of day
    I am currently getting around 52- 53 mpg on my gen2 prius however ambient temps are going to drop so I am more than expect a drop in that current reading
    #44 NortTexSalv04Prius, Nov 7, 2018
  5. Ed56
    Ed56 Junior Member
    US
    Is it normal to have two squares, in gas tank dash display to drop upon travelling only 40 or 50 miles?
  6. Mendel Leisk
    38,253
    Maybe more so with second gen with the variable of the internal bladder in the gas tank? My guess would be a touchy gas station pump that shut off sooner than usual.
    padroo likes this.
  7. George W
    George W Active Member
    909
    510
    San Antonio
    I'm getting better mileage in the mild winter of South Texas. The hotter than hell 'window' of 6 months in our Summer strains the battery. The ICE is turning more often
  8. George W
    909
    510
    San Antonio
    Did you buy normal tires or thr LRR tires? I have read that the low-rolling-resistance tires actually start with worse fuel economy until they get broken in.
  9. Mendel Leisk
    38,253
    That sounds like a tire salesman brush-off tactic.
  10. George W
    909
    510
    San Antonio
    I don't sell tires, that suggestion was made to me by an established member of this forum.
  11. Mendel Leisk
    38,253
    Sorry, I'm not saying you do, just that it sounds like it might have originated with a tire salesman.
    Also, "low rolling resistance" is a very loosely defined term in North America, with no official testing: manufacturers tend to put that tag on a broad range of tires, some a lot better than others.
  12. fuzzy1
    10,048
    The normal line in this forum is that such applies to all tires, not specifically to LRR tires.
  13. George W
    909
    510
    San Antonio
    funny that this forum is the first and only place I've ever read it
  14. padroo
    padroo Senior Member
    2,763
    2,250
  15. Tynyyn
    Tynyyn Member
    102
    27
    Bella Vista Arkansas
    I live in southern Missouri and we have constant temperature changes throughout the winter months. Some days are sub 32* while the next few days might be above 60*. While driving during the cold temps. I've noticed that the fuel mileage in my gen2 prius is around the high thirties. When the temps. are over the mid fifties then the mileage raises to the lower 40's. The changes in fuel mileage is NOT due to a wonky A/F ratio sensor or a plugged air intake, but rather to …..cold temperatures. One day the temp could be 12*F and my fuel economy will be 38 mpg even when babying the throttle. The very next day the temperatures could raise to 60*F and I can hammer the throttle and my FE will jump to mid 40's. Then the next day back to 32*F and the FE drops to high 30's. Nothing on the car has changed, in fact the only change is the ambient air temperature.
    So the air temperature is the main culprit to poor FE in the winter time. Now for kicks and grins, come back in the middle of summer when the temps jump to 100*F and see how the FE jumps. I bet your Prius would be hitting close to 45+mpg during those temps.
    Prii seem to love hot temps and hate cold temps. Just my two cents.
    Shelby profita likes this.
  16. bisco
    48,996
    yep, once a/c weather arrives, my mpg's start dropping again
  17. Paul Schenck
    Paul Schenck Active Member
    522
    306
    Fresno, California
    Battery performance in colder weather does have a more dramatic effect than running the a/c in 100 F on mpg
    I can drive up into the mountains and drain my warm battery, park over night at 32 F upon starting the car the ICE (internal Combusion Engine) runs at 1500 RPM until the battery is over half full and the cab has reached it’s 72 F set point.
    The point I’m making is that the car will get the best mileage if I drive it while it’s warming up.
    iPhone ?
  18. monzagorilla
    monzagorilla New Member
    Western NY State
    Couple of thoughts... I live in western NY State so winters can be cold. The ICE is not a very large engine so on very cold days it probably can cool off pretty quickly. A cool gas engine means it needs a richer air/fuel mixture. And of course it needs to run more to keep the heater warm. Hence poorer gas mileage. Winter gas is blended differently leading to poorer mileage. Cold weather lowers the pressure in your tires and that contributes to lower mileage too. I also run snow tires in the winter which are softer rubber which has higher rolling resistance. Again, impacting mileage. Of course, the amount of ethanol in gas (boy ethanol is a dumb idea) will also impact mileage.
    Shelby profita and Andyprius1 like this.
  19. underdog
    underdog Junior Member
    New England
    This is helpful. I neglected to consider this in reviewing my mileage.
  20. itseric
    itseric New Member
    Diamond Bar, California
    I haven't experienced as big of a difference as the others here with the drop in MPG, but that being said.. it's most likely the fuel
