Possible Monthly install meets. Bay Area-Fremont
Discussion in 'Local Prius Club Main Forum' started by Priusmpg, Jul 1, 2014.
  1. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    So been out for a while but getting back in and have 2 things I'd like to work on (without the obnoxious HOA guy who likes to complain about people working on their cars on their own driveways): a trans fluid flush, and possibly finishing screening my eng compartment penetrations against rodents.
    I've not read through mosta the 30 pages of posts since I first attended one o' these meets. Does the guy with the auto shop (PriusMPG?) still have his shop open? Are they still at his place or have the meets moved?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,264
    15,515
    Bay Area, California
    2019 Prius Prime
    They’ve moved and only happened at @Rebound ’s place a couple of times in Fremont ;).
    Otherwise they have been north along 680: Lafayette and Fairfield :).
    You are welcome to stop on by at one of the upcoming ones. Keep monitoring here for more details (y).
    SFO and acceleraptor like this.
  3. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    Okay, whoa.. that's far, hahaha. I usually drive to Berkeley once every week or so and that already feels far..
    Raytheeagle likes this.
  4. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    I guess there're no meetups near Fremont anymore? Hmm..
  5. Raytheeagle
    11,264
    15,515
    2019 Prius Prime
    Maybe @Pedal Logic will chime in and might have availability ;).
    That would make it about half way from Milpitas :).
    The trans drain and fill is easy to do at one of the meet ups(y).
    SFO likes this.
  6. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    Yeah, I'd wavered between changing it every 30k then getting suckered by Toyota's "good for the life of the car (our warranty periods)!" spiel. But also been busy so I'm coming close to 90k now and don't think it was ever done (though I should double check my service record docs). I don't think I've jackstands anymore or not sure where they are.
  7. Raytheeagle
    11,264
    15,515
    2019 Prius Prime
    We’ve got them and a pump to make the change easy;).
    I’d change it sooner rather than later as the “lifetime” fluid claim doesn’t remove some of the break in debris. I changed the diff fluids in our 2017 Lexus RX450h at 6500 miles and they were both purple versus a reddish tint:cool:.
    While color doesn’t indicate the whole story, it told me an early change is worth something :).
    RMB and acceleraptor like this.
  8. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Let us know what day works for you, I can plan accordingly too. ;)
    Manager will take a long vacation in January so it would be perfect time for a meetup. :whistle:
    Perhaps lowering springs and strut tower bar while I’m at it? LOL :rolleyes:
    w84me and Raytheeagle like this.
  9. Raytheeagle
    11,264
    15,515
    2019 Prius Prime
    As we get our calendar populated with January dates, I’ll have a better idea of what’s going on.
    But for me I believe the above identified Sunday works as of now :).
    If Pedal Logic chimes in with his availability, that might change though:cool:.
    But I’ll text him later and see what he thinks(y).
    RMB and SFO like this.
  10. Rebound
    Rebound Senior Member
    3,994
    2,642
    Portland, OR
    Sure, maybe we can plan one here in Fremont soon. Transmission refill isn't too bad.
    The rodent screening is best done if you also replace spark plugs, which is a 120K mile event. That's because you have to remove a bunch of the same stuff in both cases.
    I'd say we probably ought to do one or the other in a single day's meetup but not both... but if Ray comes, we'd probably get all of it done.
    SFO and Raytheeagle like this.
  11. Landon51
    Landon51 Member
    190
    63
    US
  12. Raytheeagle
    11,264
    15,515
    2019 Prius Prime
    Good to see you post. Happy new year ;).
    I know you’ve been slammed with other things, so what’s your availability?
    Keep this updated and I’m sure we can work something out(y).
  13. Raytheeagle
    11,264
    15,515
    2019 Prius Prime
    Would you have some things you’d like to do, or would this be for social aspects?
  14. Landon51
    Landon51 Member
    190
    63
    US
    Both. I really want to change coolant n inverter.
  15. Raytheeagle
    11,264
    15,515
    2019 Prius Prime
    Well that’s easy;).
    Where are you located :whistle:?
    Happy new year (y).
  16. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    I'm in Milpitas. Just gonna do rodent screening and trans flush since I'm at least 30k away from spark plugs.
    My most convenient times're actually weekdays, M or F.
    Currently reading up on oil catch cans but nothing yet on what I want to do specifically about that. Curious about anyone else who's put one in or an air-oil separator, and, if so, how it's working, where they placed it, etc.
  17. Raytheeagle
    11,264
    15,515
    2019 Prius Prime
    I have a catch can on our 2010 and I mounted on the front cross member;).
    Haven’t caught a lot of stuff, but it has caught some so that means it is working:).
    Maybe a Friday could work:whistle:.
    Our calendar comes tomorrow so the wife will then let me know what's available(y).
    acceleraptor, NutzAboutBolts and SFO like this.
  18. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,692
    1,736
    Bay Area
    Ray, open a shop in Dublin lol
  19. Raytheeagle
    11,264
    15,515
    2019 Prius Prime
    You got space at your palace:p.
    If so, pencil me in(y).
    SFO and NutzAboutBolts like this.
  20. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Depending on the weekend I may be able to come by.
