1. lohikaarme
    lohikaarme Active Member
    337
    337
    NY
    2023 Prius
    Limited AWD-e
    I had to disconnect my battery to work on something and after reconnecting everything works but the ICS. There is not a malfunction, just an ICS flashing indicator and a message that it is unavailable when the car is started. Looking in the user manual on page 356 there is a bullet that describes the issue:
    "System initialization may not have been performed after removal and installation of the 12-volt battery. Perform system initialization".
    There is no reference on how to actually perform the initialization. Has anyone run into the same issue and if so can tell me how to kick this off?
  2. lohikaarme
    337
    337
    NY
    2023 Prius
    Limited AWD-e
    I might have found the answer. On page 384 it says "drive the vehicle straight for 5 seconds at speeds >22 MPH"
    It is cryptic because this references how to reset the advanced parking system and does not call out the ICS but it says it needs to be done after the battery is replaced. I am going to see if it works and if it does I hope this thread serves to help future people that run into battery removal because the manual is confusing as hell.
    EDIT:
    That is the solution. Drive the car for 5 seconds at >22MPH and suddenly you can turn the ICS system on again.
    #2 lohikaarme, Apr 20, 2017
    iDealShopper, DonD, Adam1a and 4 others like this.
  3. Prodigyplace
    12,469
    11,724
    Central Virginia
    @Tideland Prius should make this a sticky. People will have this issue whenever they disconnect the 12V battery.
  4. Tideland Prius
    16,514
    Done
    krmcg likes this.
  5. eric1234
    eric1234 Active Member
    391
    200
    Hamden, CT
    What is ICS?
  6. Prodigyplace
    12,469
    11,724
    Central Virginia
    ICS - Intelligent Clearance Sonar. A set of ultrasonic sonar sensors positioned around the vehicle to not only assist the driver in determining the proximity of objects around the car, but to also provide braking force at very low speeds by automatically stopping the vehicle if the car determines that an impact is imminent. This feature works essentially at speeds you would be when parking the vehicle.
    From PriusChat Glossary | PriusChat
    RCO and Tideland Prius like this.
  7. Tideland Prius
    16,514
    Lol. I was giving you a "like" for the excellent explanation - then I realised you got it from the PC glossary.... which I wrote. :LOL:
    Valiant V, davran, Praeluceo and 3 others like this.
  8. Prodigyplace
    12,469
    11,724
    Central Virginia
    Great minds think alike, but fools seldom diiffer... ??? :LOL: :eek:
  9. Roxannelsm
    Roxannelsm New Member
    Austin
    2018 Prius
    The day after I drove through deep water on the road, I got the ICS error. It did NOT resolve after driving over 22 mph for 20 Minutes. I'm hoping it will resolve as the car dries out.
  10. lohikaarme
    337
    337
    NY
    2023 Prius
    Limited AWD-e
    Fill the car with rice?
    The reset is guaranteed for disconnecting the battery, all bets are off if this is a short due to water. You are lucky you didnt hydrolock.
  11. RRxing
    RRxing Senior Member
    2,539
    1,814
    NEPA
    Could just be dirty sensors giving the error...
  12. Toikillao
    Toikillao New Member
    Four Touring
    anyone with solution to reset ics or sensor
  13. WTig3ner
    WTig3ner Junior Member
    CA
    2018 Prius Prime
    This recurrent problem with ICS and CPSA seems to me to reflect a significant design defect. I say that as a Prius fan; our family owns four of them. But this error crops up whenever it rains. Other car companies seem to have mastered basic waterproofing. Why hasn't Toyota?
  14. bisco
    51,624
    how do we know other car companies are having less problems?(n)
  15. tomnmeg
    tomnmeg Junior Member
    24
    Peoria, AZ
    Four Touring
    I had to replace my 12 V battery in my 2016 and was told it will learn on it's own. I tried the 5 second 22 mph it said to do... WHERE are you going to do that? Down your street depending on where you live I guess. First you have to get up to 22 mph and then go for 5 seconds in a straight line. Dangerous and good luck with that. The battery needs to be disconnected while you're parked in a supposed straight line, I guess, right? That's the gist of what I got out of it. You hook up the battery get back in the car, go in line at 22 for 5 seconds? You should be on a high speed wheel roller like at the emissions places.
  16. D&D
    D&D Junior Member
    Charlotte, MI
    I had this same issue with our Prius and this solved right away!
  17. Sid786
    Sid786 Active Member
    262
    148
    Cherry Hill, NJ
    Thank you, the solution "Drive the car for 5 seconds at >22MPH" worked for me also. Although all my settings were retained only "ICS Unavailable" message pops-up. I was putting a o-ring on the battery terminal and the service guy used a told that memorizes the settings. So this is important to remember.
  18. ticedoff8
    ticedoff8 Junior Member
    47
    San Jose
    It's on page 356 of my '16 Prius Touring model's Owner's Manual.
    The car sat for 3 days and when I went to use it last night, the car's dashboard freaked out (disco lights and cycling through various screens) and wouldn't start. Turned out the aux battery (12v) was dead (8.0v) for as yet unknown reasons. Put the charger on it for 5 hours last night and, before I went to bed, I disconnected the charger. This morning it's at 12.5v and started up and drives okay. And the battery was charging at 14.5v, so I assume the DC-to-DC converter was okay.
    But the "ICS Unavailable" warning popped up, and the dash has a flashing amber warning icon.
    I first looked in the manual's glossary, and I could find nothing about it.
    Turns out I must have looked at this page sometime in the past, because when I searched for "2016 Prius ICS", I could tell by the search result's shading of the link, I had clicked on it before.
    The ICS is now available.
    And it seems the problem would have cleared itself simply by driving to the store.
    All it needed was to drive straight ahead at any speed greater than 22MPH (35KPH) for more than 5 seconds (I drove at 55MPH and the warning icon stopped flashing).
    I went back to the manual to see if it was on page 384 (it's not). The only way I stumbled on their solution was when I glanced at the page for the automatic parking assist. There was a footnote that said this was disabled when ICS was OFF (see page 356).
  19. Doug McC
    Doug McC Senior Member
    1,056
    405
    Midwest
    2022 Prius
    Approximately 161ft is approximately 2.5 residential lots, or roughly half a residential block. So this maneuver should be reasonably accomplished in less than two residential blocks, including accelerating at a very safe rate, and traveling at the required speed for 5 seconds.
