Prius 2011 Brake Sound in Parking mode and When Stopped
Discussion in 'Gen 3 Prius Technical Discussion' started by dmajeed, Jan 5, 2019.
  1. dmajeed
    dmajeed New Member
    Pakistan
    Hello fellow members,
    I have Prius 2011 1.8, when car is in parking mode or when in drive (low speed, w/o acceleration), pressing brake produces a sound which comes near the front driver side wheel. sound like pads are engaging/disengaging. I went to mechanic for inspection, he said pump is not developing required pressure and you have to replace the whole module.
    Another thing I noticed that when I press brakes, no grinding/pump/regenerative type sound which I read in multiple forums that it should be there.
    please suggest, discuss and advice about this sound issue
    No dashboard lights, A slight weakening in brakes.
    52,767
    sounds right to me, but i'm no expert. how many km on her?
  3. dmajeed
    dmajeed New Member
    Pakistan
    about 89000 km
    you are suggesting mechanic is right?
  4. bisco
    52,767
    sounds like it. strange that there are no codes. she using tech stream?
  5. dmajeed
    dmajeed New Member
    Pakistan
    thanx bisco for your time
    i don't know what is tech stream.
    and u are right, no error codes when scanned as well
  6. Mendel Leisk
    42,251
    Techstream is Toyota's proprietary sofware, for diagnostics and so on. I'd maybe just continue to monitor, considering there are no lights/codes and the repair is likely to be expensive. Did the mechanic quote you a price for the repair?
    Have the brakes been regularly inspected/serviced? Every two or three years the calipers should be pulled off the rotors, the caliper pins relubed with proper lubricant (Toyota makes a special lube for caliper pins, and there are some aftermarket lubes that are appropriate), the pads and shims should be cleaned up and relubed sparingly, at contact points. Anti-seize compound is the common name for the lube usually used for that.
    It's best to "put the car to sleep" when taking the calipers off the rotors, by disconnecting the 12 volt battery negative cable. If the car is "live" there's a possibility of the hydraulic system pressurizing, which could push a piston right out of the caliper. Opening driver's door in particular will do this.
    Also, when done, and before reconnecting the battery, it's good to press the brake pedal multiple times, ensure there is no excess travel. If excess travel is detected the car could display error lights, and it's best to avoid having to deal with them.
    One further caveat: when reassembling rear brakes, it's imperative that the pin on the back of the pad that contacts the caliper piston be between the spokes on the piston face, and firmly seated thus. The piston should be rotated to ensure this.
    Attached is the Toyota Repair Manual brake section.
    Maybe also try a brake fluid replacement first? Toyota USA says nothing on the subject, but Toyota Canada says every 3 years or 48,000 kilometers, whichever comes first.
    It is relatively easy to do, and can be done without Techstream. Here is a video:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    (video #18)
    And attached is an instruction from the Toyota Repair Manual. Again, this is a Toyota sanctioned method that does not need Techstream. It does however require the car to be in a special "invalid" mode, which both the attachment and the video show. The video is easier to understand though.
    I managed to do this myself with our car; my wife pushing the brake pedal to push fluid out. I did not have any motorized suction, just used a syringe at the beginning, to take fluid out of the reservoir.
    #6 Mendel Leisk, Jan 6, 2019
  7. dmajeed
    dmajeed New Member
    Pakistan
    thanx
    Mechanic will quote the price tomorrow. He has suggested the replacement of complete module.
    will look at the videos..
