red triangle and code 1241
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mlr, Jan 12, 2019.
  1. mlr
    mlr New Member
    new jersey
    hi everyone. have 2007 gen 2 with 189728 miles.
    red triangle blinks on sweeping radius turns ( exit from highway) code 1241 on my DOB2
    any one has any idea what may be a reason for it. Thanks
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Raytheeagle likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,268
    5,965
    Columbia, SC
    x2 on SFO
    Time to add about 2.5 quarts of oil.....
    kenoarto, JC91006 and Raytheeagle like this.
  4. JC91006
    JC91006 Senior Member
    16,488
    8,402
    x3 on SFO, TMR
  5. mlr
    mlr New Member
    new jersey
    k thanks, will work on testing the system in couple of days. let it warm up a little, freezing in new York York
  6. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    If you have the light coming on when you are going around a turn, check the oil level NOW. Don’t even turn the engine on without checking it.
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,374
    3,228
    Madison, Wisconsin
    You are low on oil.
    Check it immediately.
  8. mlr
    mlr New Member
    new jersey
    Hello again.. THANKS to everyone for help. I add oil right after conversation ( about 2 qt.) and clear code 1241, driving it since then for over 250 miles and so far no triangle and no C1241. will update post if any changes
  9. Patrick Wong
    18,200
    6,479
    And have you checked engine oil level again, after driving 250 miles? If not it would be good to do so, so that you can understand the extent to which the engine is consuming oil.
    You do not want to wait for warning lights to appear, before you decide to check the engine oil level. If you continue to allow the engine oil level to decline so much in the future, get ready to buy a new vehicle or pay to have a replacement engine installed.
    Skibob likes this.
