Accident Prime Advanced - Collision (released from hospital)
Discussion in 'Prime Main Forum (2017-2022)' started by Sid786, Jun 3, 2018.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    while using cruise control below 50 F:eek::eek::eek:
    huskers and Mark57 like this.
  2. priuscatprimeguy
    2,730
    2,640
    Welp, another accident where someone was getting out of her car via the passenger side from the drivers side because the driver side door didn't work, she was trying to get the lift gate of the apartment complex to open by entering the apartment number on the keypad, she failed to do that, gets back into her car via the passenger side door maneuvers to the drivers side and accidentally shifts the car into neutral thereby her car rolls backwards into my car, there were cars behind me so, smash bang 20190102_134010.jpeg
  3. Mendel Leisk
    38,210
    I was walking the dog, idly thinking "Toyota should get together with Jeep, make iteration of Prius that can take a slight tap."
    It's no big secret: don't festoon the front (or rear) with chandeliers. :confused:
    Merkey, jerrymildred and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    When do you trade in your garage queen for a Jeep again:whistle:?
    Merkey, jerrymildred and Mendel Leisk like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Golly!!!
    Amazon says this won't fit my car, but as they say, where there's a will, there's a relative.
    Merkey likes this.
  6. ClemsonSteve
    ClemsonSteve Active Member
    270
    247
    South Carolina
    Wow! I'm happy that no one was hurt!
    priuscatprimeguy likes this.
  7. Sid786
    Sid786 Active Member
    262
    146
    Cherry Hill, NJ
    Wow, just a small tap can do this damage. The entire front assembly will be replaced. Can you please update us with the total cost of the bumper replacement, as I think most of us will go through it at some point in future.
    Merkey likes this.
  8. priuscatprimeguy
    2,730
    2,640
    Got an estimate of about $1700.00, will update with actual results when Uber eats and Progressive decides whose paying
    jerrymildred and Merkey like this.
  9. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    didn't someone say that the radome (Toyota emblem) was ridiculously expensive?
  10. Tideland Prius
    16,066
    Yes. $468 or thereabouts.
    alanclarkeau likes this.
  11. jerrymildred
    11,491
    14,100
    Tampa, FL
    :eek: That's crazy!!!! Talk about being proud of their product.
  12. Mendel Leisk
    38,210
    The whole panel is $468 (which is ridiculous). The Toyota emblem not so much?
    It just pisses me off to hear these pieces of plastic dreck referred to as "bumpers". Or to hear statements like "I need some protection for my bumper".
    Rant on: "the thing is supposed to BE the bumper, fer chrisakes".
    fuzzy1, Andyprius1 and jerrymildred like this.
  13. priuscatprimeguy
    2,730
    2,640
  14. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    The Radar sensor is enclosed therin.
  15. Andyprius1
    2,327
    859
    Cool CA
    Mendel, That whole progressive body crunch system is for our safety, it starts with the bumbers!
    Underneath is a very thick and real steel bar which probably also has some predicated crunchability.
    Altho we Seniors may not like or agree with it, I’m sure numerous lives have been saved because of it.
    Plus it increases insurance, promotes body shop profits and in general makes everything cost a lot more!
    That’s the American way, right ? Just make sure YOU are not at fault. Andy
    #235 Andyprius1, Jan 15, 2019
    Mendel Leisk and alanclarkeau like this.
  16. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    Check out some of the OLD vs NEW crash tests:
    AND - if you think Steel Bumpers would have helped:
    The other thing not mentioned in the tests above is that in a 2016 -> PRIUS the AEB would have triggered, meaning that it would have likely slowed dramatically before hitting, lessening the impact. Thanks, RADAR detector and Camera.
  17. Tideland Prius
    16,066
  18. Mendel Leisk
    38,210
    They should make the crumple zones cheap and utilitarian. The current front ends are first and foremost styling exercises, very fragile and expensive ones.
    Also recess the license plates, to avoid even the slightest love tap embossing the car ahead with the license plate mounting bolts. :rolleyes:
    #238 Mendel Leisk, Jan 15, 2019
    Andyprius1, alanclarkeau and fuzzy1 like this.
  19. alanclarkeau
    7,041
    7,580
    They did back in the late '70s - remember the ugly crash bumpers
    upload_2019-1-16_13-44-57.png upload_2019-1-16_13-47-0.png upload_2019-1-16_13-47-46.png
    But, while they were able to take impacts up to 5mph (?), they found that the damage at just slightly more than that was more costly. And - it had to be hit at the "correct" height, and straight on - if slightly higher or at an angle, the damage could be more costly.
    At the same time, manufacturers, particularly VOLVO, MERC et al were trying to build in better and better crumple zones. And the 2 didn't work together seamlessly, which I believe is why they dropped the 5mph bumpers - and try to save lives instead.
    Andyprius1 and Mendel Leisk like this.
  20. El Dobro
    El Dobro A Member
    6,972
    3,209
    IIRC, Ford had bumpers filled with water to absorb impacts. They had plugs that would pop out to let the water out.
