Buying a Prius with 270k
Discussion in 'Gen 2 Prius Main Forum' started by Jordan Peters, Jan 16, 2019.
  1. Jordan Peters
    Jordan Peters New Member
    Louisiana
    Hey everyone,
    I’m in the market for a Prius, with a budget of $5.5k. It’s been pretty daunting for me finding a good deal, as most of the cars within my price range are just at that point where I’d start to worry about a battery. Also, People around here (Louisiana) tend to replace the battery and then tack that cost on to the car. So there’s a lot of 120k gen 2’s with original battery for 5k, and a lot of 150k gen 2s with new Toyota batteries for 8k.
    I’ve found a few I like, but one is standing out at me right now due to the deal offered. It’s a 2007 with 270k miles, the battery was replaced at the dealer in 2015, 80k miles ago, and the seller wants $2500. It does have some minor damage to the front fender that I could repair myself for cheap.
    Am I right in thinking this is a pretty good deal for a car with a 3 year old battery? Is there a bunch of other stuff I should be worried about for this high mileage? Should I stick to cars around 100,000 miles/hold out for one closer to 120k with a new battery?
    51,486
    depends on how many miles a year you drive, and how long you want to keep it. but yeah, that's close to end of life
    if you diy, buy a lower mile one that needs a battery and install a new $1,600. battery
    if you don't, stick with low mile prius, they are expensive to fix.
    scona likes this.
  3. oldtechaa
    oldtechaa Active Member
    336
    223
    NZ
    2013 Prius Alpha
    I don't think that's a terrible deal. I paid $3800 for a 2008 with 216k with original battery. Depending on how it was maintained, etc., that could change a lot.
  4. padroo
    padroo Senior Member
    2,763
    2,251
    If you need this car every day I would not buy it. Even with a new battery the engine and the rest of the car has way too many miles to be dependable. If you are a DIY type then maybe, if not avoid it.
  5. AlwaysDrivingFL
    AlwaysDrivingFL Junior Member
    24
    Central Florida
    If you don’t mind driving, expand your search. Tampa Hybrids has some in that price range. Dealers in central Florida are sending them to auction or selling them to local used car dealers - at least that is what I found the last few weeks. So don’t be afraid of checking the lots near you - and I discovered you can buy a car fax on eBay for under $5. That helps you get a general feel for it.
    The guy I bought mine from this week buys from a handful of dealers in Orlando - before they send them to auction. That is the price point you are shopping at - a good car traded in headed for auction. There seems to see a lot of them in the 110-150k range around here. I was able to pick up my 2008 Touring for 3950, with 150k. It is super clean and the car fax service was good (along with the Toyota owners list).
    Also try calling the dealers that would get them as trades - and ask if they have any as is cars headed to auction you can look at (and drive, be sure to drive every single one before you buy though - I can tell you the problems with the cheaper ones in fl right now lol).
    Oh and I didn’t know, but the car fax app lets you search for cars and save them - they then apparently email you when similar vehicles are added as I’ve discovered this week.
    Lastly, the only other car I felt came close in mileage was the corolla, so I kept them in my search in case a clean one popped up.
    Good luck!
    SFO likes this.
  6. MilkyWay
    MilkyWay Active Member
    823
    359
    MI
    $2500 is really cheap for a car. Usually around 180k and up the gen 2s start burning oil. It's almost inescapable. And the sellers a lot of times will look you in the face and say "it doesn't burn any oil" but you'll find out it probably does. Not that big of a deal if only adding 1x between changes but sometimes you have to add every 1200 miles or so which gets tedious. That would be a worst case scenario for oil burning.
    Then your normal stuff like struts, brakes, wheel bearings.
    And of course condition is important (my #1) I would take a 50 million mile mint condition vehicle needing an engine/trans over a 50k mile car that is beat up in and out.
    But at $2500 can't go too wrong.
  7. oil_burner
    oil_burner Active Member
    249
    126
    not a terrible deal but definitely budget for some maintenance items such as new shocks/struts, plugs, possibly brakes, etc. I bought my Prius with 218k and at 271k the head gasket is letting go. I can't complain because the car cost me under $2k so in the grand scheme of things isn't that much money and I drove it harder than most people ever would. If you're inclined to roll up your sleeves to tackle small items then go for it.
  8. LewLasher
    LewLasher Member
    244
    66
    Cambridge, Massachusetts
    2019 Prius
    XLE AWD-e
    And here I thought it would not even be worth it to try to sell my 2006 with 262 kmiles (and counting)!
    MilkyWay likes this.
