My struts are shot. Which suspension will give me the most comfortable ride in rough city street?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NYC_Prius_, Aug 22, 2018.
  1. NYC_Prius_
    NYC_Prius_ New Member
    Queens, NY
    I'm driving in a 2013 Prius 3 around a 1000 miles a week mainly in NYC for Uber. At this point it feels like I'm driving a boat. I've seen the Koni and the KYB brand of strut replacements but not sure what is better in my situation. I really need something that will soak up the potholes as much as possible. If anyone can lead me in the right direction I would greatly appreciate it.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
  3. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    I installed KYB's but dont expext a magic bullet. They improved ride but its still a prius not a caddy.
  4. Ballbearing
    Ballbearing Junior Member
    Huntington Beach, CA
    I just replaced my shocks a month ago with the KYB Excel-Gs. Ride quality and comfort is back to normal. Depending on your mileage, I'd recommend replacing the strut mounts, which is what I did, since my originals were at 200K and I didn't want to replace them again.
  5. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    I rplaced everything, struts, springs, upper mounts and lower seats and all new fasteners. My prius sat for 2 years so i make a habit of replacing fasteners as i go as many are corroded.
  6. danielscottclark
    danielscottclark New Member
    Seattle
    I think I need to do the same here. Driving rideshare in Seattle.
    Is this a diy with a pair of jack stands and a scissor jack? How do you jack up the axel properly so it doesn't fall?
    How do you tell / know if your shocks are shot?
    Do you need an alignment if you do just the back since it isn't aligned...?
  7. 04priusnow
    04priusnow Active Member
    345
    201
    koni for me.. rides great and works well with factory or trd springs IMG_20190124_184331.jpg
    PH-1 ?
    afpri likes this.
  8. tonynap
    tonynap Member
    43
    NY
    I used the KYB Strut-Plus assembly and am happy with the results.
    KYB SR4245 (R)
    KYB SR4246 (L)
  9. Ashy Anklez
    Ashy Anklez Junior Member
    Atlanta
    Have you had any issues?
  10. tonynap
    tonynap Member
    43
    NY
    None at all.
  11. Mendel Leisk
    41,580
    This is a pretty cool slo-mo conversation. (y)
    CR94 and tonynap like this.
