Car won’t start. Could it because of the snowstorm?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by justin alverson, Jan 19, 2019.
  1. justin alverson
    justin alverson New Member
    Topeka
    So i have a 2008 Prius last night i went to start my car and it wouldn't start last night we had a snow storm could that have anything to do with it not starting
  2. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    It's highly doubtful.
    When you say failed to start - did it crank over and just not start, or did it just do nothing at all when you turned the key.
  3. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    Turned the key?
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Turn on the headlights and see if there bright. If not you have a dead 12 volt battery that's in the trunk on the passenger side.
    Battery is probably very old.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Cold Temperatures can affect a lot of things.
    Most notably a 12 volt battery that might be weak.
    On a Prius, the 12 volt battery doesn't crank anything. My understanding is that the 12 volt battery boots up the system, and the HV battery actually starts the engine. 12 volt boots up the system. The Prius doesn't have an alternator, and the 12 volt isn't used to start the engine directly like a regular internal combustion engine vehicle, so you sometimes don't get the same warning..slow cranks, that you would get with a regular vehicle.
    So it would be helpful to know exactly what you mean by not starting.
    Is anything booting up?
    Other symptoms as asked, like dim lights?
    My first suspect would obviously be the 12 volt battery. But it could be anything from fuses to a loose connection to some other as of yet unknown.
  6. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    Only some Priuseses have the fancy cloud-enabled cordless witchcraft key. Some still use a cut metal shank with twisty requirements.
  7. The Electric Me
    9,083
    5,801
    I think that's exactly what the dealership called it on my window sticker when I bought my Honda Fit.
    It was right below the Amazing Outdoor Environmental Interaction Portal (Sunroof).
    Seriously though in 2008 weren't the majority of all Prius push button start?
  8. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    All true, except for the “c”;).
    Guess what @dubit has:whistle:?
  9. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    lol - I forget about the push button gizmo you all have sometimes
  10. dolj
    dolj Senior Member
    8,509
    4,318
    Wellington, New Zealand
    Which is why people should stick to their own forums, unless they are 100% fully confident in their knowledge of the Gen 2.
    It gets quite tiresome correcting incorrect advice.
