P261B and cold heater core hoses
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by David Allison, Dec 16, 2018.
  1. David Allison
    David Allison New Member
    Ohio
    im getting code p261b and the check hybrid system message. The pump seems to be working. (Replaced it under 10k miles ago).. The pump seemed to started giving me the message once it got cold here (assuming its from going below 60°f which I've heard some pumps want to give this message when under 60°f) I also noticed that my heater core hoses feel cold. I was wondering if this could be multiple issues or if its possible that I have a huge air pocket causing both these problems?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
  3. Ben Schneider
    Ben Schneider Junior Member
    central florida
    just searching through this code... maybe replace thermostat ?
