Burning 3.9qts every 1000 miles
Discussion in 'Gen 2 Prius Main Forum' started by Fatmatt86, Dec 5, 2018.
  1. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    If I read the same post as you, I don't think he said to do that. From what I remember, it was using ATF as an engine flush while doing the oil change. That's what I'd be doing, if I was trying anything at all.
    The paint thinner and carb cleaner were used as a piston soak.
    #61 dolj, Jan 31, 2019
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Apparently you are right.
    Sorry.
  3. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Well, I picked up a bottle of sea foam and stuck 4 ounces in the oil and 12 ounces of seafoam in the gas tank, which had about 5gallons to maybe clean the cat enough to drop the check engine light. I've already ran through the gas and it's still on. Currently at 246,804 miles. We'll see if the seafoam has any effect on the oil.
  4. sam spade 2
    7,035
    2,788
    2017 Prius c
    It certainly made the oil thinner and that should make it disappear quicker.
    IF, and only if, your problem is caused by stuck rings, it might help some.
    Highly unlikely.
  5. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    The stuff is thinner than 5w-30 oil? That’s practically thinner than water already.
  6. sam spade 2
    7,035
    2,788
    2017 Prius c
    It contains mostly naptha (white gas), alcohol and petroleum distillates (kerosene), all of which are solvents that ARE thinner than water.
  7. Rmay635703
    Rmay635703 Senior Member
    2,594
    1,612
    Somewhere in Wisconsin
    2013 Chevy Volt
    Solvents like acetone are as thin as water,
    Generally once you get the motor warm the sea foam should vaporize out but personally I would use it or MMO to soak only and not for running in the oil during a change.
    Compounds that make rings seal better should help your consumption issue,
    Now what could those be?
  8. oil_burner
    oil_burner Active Member
    249
    126
    your engine is done, no snake oil in a bottle is going to fix having been run low on oil that many times. Sooner or later you're going to get rod knock and then soon after that it won't even run. Why not use this opportunity to look for a junkyard motor to swap in if you want to keep the car.
    dubit likes this.
  9. Mendel Leisk
    38,718
    Lottery on when it seizes, pick the mileage, closest wins who knows.
    Fatmatt86 likes this.
  10. golfmk681
    golfmk681 Active Member
    262
    105
    los angeles, ca
    That's a good run. I'd swap the engine and keep it going. That's my plan :)
  11. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Found this post in my neighborhood today. Maybe someone has been stealing my oil... LoL. Highly unlikely, though. I'm a Gambler, willing to make a bet that it reaches over 300,000. I have gone to a junk yard and they have 2 prius. The owner said the engines were $100 if I took it out myself, $200 for them to take out, and $350 with warranty. Gonna drive the original till it goes out. I feel it's got Alot left in her, despite all the posts that it's shot, and not gonna last much longer. Already put over 60k miles in it's current condition, what's another 60k to 300k
    Bunce likes this.
  12. padroo
    padroo Senior Member
    2,763
    2,250
    O2 sensors don't like oil or coolant, they get contaminated.
    If I were buying a used engine I would do a cylinder leak down test on it before I pulled the engine.
    If it won't pass this test it is junk. That's not to say the engine couldn't have other problems but it would eliminate one variable.
  13. Aztechmaster
    Aztechmaster Member
    76
    S.D.
    Leak down test only checks compression rings not oil control unfortunately.
    Prius Rising likes this.
  14. Mendel Leisk
    38,718
    Ok, so it's around 240 now? I'll take 270. Probably lose my shirt.
  15. padroo
    2,763
    2,250
    Reread my post, I mention that there could be other problems. Not too many things you can check in an junk yard engine until you start it.
  16. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    How much if they install it?
    Raytheeagle likes this.
  17. Mendel Leisk
    38,718
    IIRC someone here got a 2nd gen install, and it was almost while-you-wait, around 4 hours. I guess you pretty much HAVE to wait, if that's you're only ride, lol.
  18. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Said they wouldn't install it.
    SFO likes this.
  19. oil_burner
    249
    126
    $200 for them to pull it is a steal if the engine is in good shape. I just paid $500 at a local junkyard. Hell, what's $100 these days, 4 tanks of gas?
    SFO and Fatmatt86 like this.
  20. sam spade 2
    7,035
    2,788
    2017 Prius c
    Depends on exactly HOW they remove it.
    IF.....they do things like cut wires and hoses and pipes......then it might not be such a good deal after all.
