Prius Battery Fan Check Up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ePRIU$, Feb 1, 2019.
  1. ePRIU$
    ePRIU$ Junior Member
    35
    I watched YouTube video on how to clean battery fan and tube and it requires to take the side panel off! Is there a way to check or to clean the blowing fan without taking any parts off? There must be an entry for air to come in where I can use a vacuum to suck dust out, thanks.
  2. Threej
    Threej Member
    99
    99
    Portland, OR
    How often have you cleaned a fan?
    Dust reacts with moisture in the air to make it somewhat sticky and attach to the fan blades. Vacuums will only have minimal success in removing this, and usually requires some sort of physical contact/abrasion to remove.
    The NutzAboutBoltz videos are our community favorites here at Priuschat.
  3. bisco
    52,351
    You can pull the grille off of the back seat and do your best from there
  4. Mendel Leisk
    41,861
    Good video above. My only comment would to not bother pulling the rear seat off: you can just push apart the seat and back, reach through with a ratchet extension, to remove the single 12 mm (socket size) bolt in there.
