Car hesitates when going from EV to ICE
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by our1vue, Jan 29, 2019.
  1. our1vue
    our1vue Member
    313
    58
    NY
    Hi all,
    I have a 2012 Prius 2 with 116K miles. I drive down a long hill that turns into a level road for 10
    miles. When I drive down the hill, the batteries get fully charged. Then the car switches to EV
    mode when I'm on the level part. When the battery gets down to 3 bars, it feels like some one
    is lightly stepping on the brakes. Then after 3-4 seconds, the engine will start and the battery
    will immediately drop to 1 bar. Once the ICE is running the battery will charge up and everything is fine.
    There is no dash lights when all this happens. And of course it is intermittent. I thought that
    this problem was what TIFF was having, but I have no lights. Thanks for any help.
    Tiff likes this.
    52,274
    try not driving ev so much after coming down the hill. force the engine on by stepping on the gas harder when you're at 5 or 6 bars. put it in power mode.
  3. our1vue
    our1vue Member
    313
    58
    NY
    Bisco,
    Thanks for the suggestions. I'm not going in EV mode on purpose, the car is doing that itself. Also when I step on the gas, the
    ICE starts right up. It is like the car gets confused when the batteries are low and forgets to start the ICE to charge them.
  4. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Looks like you have some weak cells, not providing enough amps
    Get a volt reading when the battery is low
  5. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Your hv battery, when healthy should drop only to 2 bars and no less.
    Tiff had a P080a and my guestamation is That that code will trouble you also later :(
    Tiff likes this.
  6. our1vue
    our1vue Member
    313
    58
    NY
    4est,
    How do you measure the voltage ? Thanks
  7. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Dr prius or other apps + bluetooth obd
    Or techstream
  8. bisco
    52,274
    112k is early for a bad battery, but not unheard of.
    Maybe it’s the hills
  9. Tiff
    Tiff Junior Member
    86
    Crawley
    Well im still suffering with this issue. But problem is that its intermittent. Sometimes you would think its a brand new car and others not quite.
    Now our1vue is being forced into ev where as ive noticed when it goes into this funny mode then ev is not available although battery shows as charged.
    Try torque pro and add predefined pids for prius that has the voltages in there Although for me its not working. I have the pids but they wont display the data. Give it a try see how you get on
  10. Tiff
    Tiff Junior Member
    86
    Crawley
    Any luck? Still same or did you sort it
  11. our1vue
    our1vue Member
    313
    58
    NY
    I wimped out and made an appointment with the dealer. Us software engineers are told to leave the hardware to the EE :)
    I'll update this thread with what they find.
    bisco and Mendel Leisk like this.
  12. our1vue
    our1vue Member
    313
    58
    NY
    just to follow up, 2 days ago the check engine/ hybrid system light came on. It had a code P0A80 which says there is
    a problem with the hybrid battery. Car has 118K miles on it. Never did take it to the dealer before the light came on.
  13. Mendel Leisk
    41,814
    Have you checked are you in/out of warranty?
    Even if out, pretty close: Toyota's been known to come up with some goodwill compensation, say 1/2.
  14. our1vue
    our1vue Member
    313
    58
    NY
    Hybrid batteries are only warranty for 100K (I'm 18K over). I traded in the car for a chevy.
  15. bisco
    52,274
    congrats, well done!(y)
  16. bisco
    52,274
    i thought ny was a carb state?
  17. our1vue
    our1vue Member
    313
    58
    NY
    bisco,
    Yes it is, but the batteries are only covered up to 100k. Now if the batteries caused the car to fail the emissions test, then they
    would be covered. But I doubt the car would fail if the batteries can't start up the ICE anymore :)
  18. bisco
    52,274
    interesting, it's like 'carb lite' :cool:
    RMB likes this.
