What's this?
Discussion in 'Gen 2 Prius Technical Discussion' started by Tynyyn, Feb 8, 2019.
  1. Tynyyn
    Tynyyn Member
    109
    29
    Bella Vista Arkansas
    Backseat, passenger side, between the seatback and the pillar is a rectangular box with a grill on it. It sounds like it blows air yet I don't know of a switch that turns it on.
    What is that box and what does it do?
    Thanks
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    If it looks something like this:
    It is the hybrid battery air intake, it is very important not to block it.
    The back of that looks like this:
    It is thermostatically controlled, if your big battery gets hot, you can hear it.
    (I am not sure all these photos are from a Gen 2, but the idea is the same)
    #2 JimboPalmer, Feb 8, 2019
  3. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    There is a picture of it in your owners manual telling what it is and not to block it.
    Raytheeagle and jerrymildred like this.
  4. dolj
    dolj Senior Member
    8,438
    4,288
    Wellington, New Zealand
    The owner's manual! Who'd a though it contained such good information! :whistle:
    Skibob and Prodigyplace like this.
  5. bisco
    51,895
    if you pull the grille off, it leads down a very interesting rabbit hole
    iron-icman and Raytheeagle like this.
  6. Tynyyn
    Tynyyn Member
    109
    29
    Thanks, fellows for the replies. I wouldn't have thought it was for the battery. It was cold outside, 12*, and I had my heater on full blast. I got hot while driving and turned the fan off and then I heard a very loud fan sound coming from the battery cooling fan. It just bugged me that the sound was so loud. I figured the fan was going to fail. But after a few seconds the fan stopped turning and it became quiet again. Maybe the fan started because it was hot in the cabin.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Where’s Elmer Fudd when you need him:p.
    Skibob and bisco like this.
  8. bisco
    51,895
    hunting wabbits
    Skibob and Raytheeagle like this.
  9. dolj
    dolj Senior Member
    8,438
    4,288
    If the cabin was in the 86ºF+ (30ºC+) range, then almost more than likely. Try and keep the cabin in the 64-75ºF (18-24ºC) range.
    If it was in the cooler range, then that could a sign that your HV battery is not in the best shape.
  10. bisco
    51,895
    you have a 15 year old battery
    edthefox5 likes this.
  11. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The battery is not outside, it is in the cabin with you.
    Besides the possibility that the cabin was too hot, did you go down (or up) a long hill? Changing electricity into chemistry is going to generate heat.
    Talimena National Scenic Byway Home - Talimena National Scenic Byway
    as an example, but that seems south of you.
    #11 JimboPalmer, Feb 8, 2019
  12. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    Keep my number in case you ever need anything. I'll be glad to help in any way.
