Strange low frequency vibration in the car & the steering wheel
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Mayank Jain, Feb 9, 2019.
  1. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    Hi everyone,
    From last few days, i'm experiencing strange low frequency vibration in the entire car and the steering wheel.
    I checked the tire pressure, all seems fine. No warning signals on the dashboard.
    I'm attaching a gif of the steering wheel vibrating.
    20190209 135103 - Upload GIF & Share Online
    Any suggestions on what might be wrong?
    Thanks!
  2. fuzzy1
    10,431
    Is one of your front tires unbalanced, or out of round, or suffering a bubble-up defect (I once had such from a puncture that didn't leak until it expelled the offending debris) on the tread?
    Mayank Jain likes this.
  3. SlidingBike
    SlidingBike Active Member
    171
    113
    Fremont, CA
    That GIF is a very good example to explain the exact situation.
    Can you check if alignment is an issue?
    Mayank Jain and Mendel Leisk like this.
  4. George W
    George W Senior Member
    911
    514
    San Antonio
    It sounds like my tires near the end of their usefull life. They looked like a normally worn tread, but underneath the top-tread was slowly shifting. The steering wheel did shake, and a 'growling' sound could be heard.
  5. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    If i leave the steering wheel, it feels like its moving to left aide in small jerks.
  6. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    Thanks for the suggestions everyone. I'll get the alignment & wheels checked first thing tomorrow!
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,149
    Tampa, FL
    Also check for broken belts in one or the other front tire. That can be hard to spot, but will make you wheel do what yours is doing.
    hotelprisoner likes this.
  8. SlidingBike
    171
    113
    Fremont, CA
    I've taken Wheelworks life time alignment deal (usually they offer it for $110 on every new years day), I get my wheels aligned for every 6 months. So far nice. (from one week, TPMS is flashing , at times going of but mostly staying.. need to have it checked though).
  9. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    Hi everyone,
    I took the car to a local tire/alignment shop - and the moment he elevated the car, the reason for the problem was almost clear.
    The front left tire had a big bubble on one side which was pulling the car left with the jerks which you can see in the GIF. We also realized that both left side tires were very old (Treads barely visible). While both of right side tires looks fairly new. All of them were Yokohama Avid Ascend (Context : I bought this car used in early Jan 2018 - with 95k miles. I've added +5k miles since).
    His recommendation (which I am planning to take)
    - Junk both left tires & buy 2 new tires
    - Move front right to rear left
    - Put 2 new tires on the front
    - Overtime, replace back tires with same brand, new tires
    I'm scheduled for Thursday at Big-O tires for the following
    jerrymildred likes this.
  10. bisco
    51,884
    congrats!(y)
  11. George W
    911
    514
    San Antonio
    Are you going to also get an alignment?
  12. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    The tire shop said they'll do a check and if needed, add alignment.
    I am currently under assumption, that the alignment might be off too.
  13. SlidingBike
    171
    113
    Fremont, CA
    I guess you must get the alignment done.
  14. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    I'll update status on Thursday after i get the new tires.
    Cheers!
  15. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    Hi everyone,
    I got the tires replaced & the car is now running like a charm!
    Got 2 new tires, moved them to rear & got realignment done.
    Thank you everyone who chipped in to help :)
    Cheers!
  16. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Good to hear, I assume the two new ones went up front and the others to the back.
  17. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    The two new ones are in the back. That's what the car mechanic shop recommended. I had no reason/insight to contest that.
    Should they have gone in the front? If so, why?
    Thanks!
  18. jerrymildred
    11,517
    14,149
    Tampa, FL
    As I understand it, repair shops want the new tires in the rear even with fwd. That's because they want the best traction back there because of the way cars respond when the rear losses traction on a slippery curve versus the front. I'm not sure I totally agree and many vigorously disagree, but I do see their logic.
  19. fuzzy1
    10,431
    Two new tires being put on back is pretty much industry standard now. There are different opinions in what amounts to a religious dispute about what is best, but legal liability pushes the shops towards the solution that works best for non-super-expert drivers.
    While front wheels do the bulk of braking in ordinary controlled perfectly-straight-line conditions, this arrangement is unstable in emergencies when things get out of control. When things start to go sideways, the tire set with the weakest braking traction wants to slide ahead of the better traction set. So if the poorer set is in back, they want to spin around and become the new front tires. Very few non-professional drivers can keep in control of the car when it is suddenly facing and sliding backwards.
    Modern ABS and skid control reduce this tendency, but can't perform the miracle of abolishing it. Symmetrical traction is intuitively much easier to control than asymmetric traction. That is why many of us prefer having (nearly) matching tires on all four. Beside replacing all four together, regular tire rotation helps keep them nearly matching.
    #19 fuzzy1, Feb 20, 2019
    George W and jerrymildred like this.
  20. jerrymildred
    11,517
    14,149
    Tampa, FL
    Yeah, there's a long rather heated thread on the topic here somewhere, but I just didn't feel like digging it up. You explained it very well right there. Thanks, Fuzzy.
