Broken torque limiter?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mitch56, Jan 25, 2010.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    Engine may have a blown broken piston rod seen a lot of those on severe oil deprived g2 motors on this site. Usually cylinder number 3. Throws it through the side of the block usually.Take the plugs out and see if the pistons are moving if turned by crank bolt.
    Sounds like it's a mess though.
  2. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    I guess you're not alone now. My 2010 even snapped the input shaft.
