Oil analysis results, 281k on an 06 Prius
Discussion in 'Gen 2 Prius Main Forum' started by golfmk681, Feb 18, 2019.
  1. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    493D3A3C-8B3D-46EE-BC33-59D26800B9D3.jpeg I just did an oil sample on my Prius and thought I’d share theresults. Currently I burn a qt of oil every 4K. I used a Fram extended oil drain filter, mobile one 5w30 high mileage oil. I planned to change the oil originally at 279k miles but decided to stretch it since I added 2.5qts of oil between the oil change. At approximate 277k miles I put techron fuel additive and used 6 bottles (1 bottle per fill up). I also used 1 bottle of ceratec oil additive at the 269k mile oil change.
    I’m impressed and happy with the results. Oil analysis was taken at 11k miles since last oil change. I’m going to try 13k mile oil change interval or 15k depending on how the car does. I’ll do another oil analysis at the next oil change.
    #1 golfmk681, Feb 18, 2019
    SFO likes this.
  2. TomB985
    TomB985 Member
    137
    68
    Isanti, MN
    Looks good, thanks for posting!
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Usually they give you either te TBN or TAN value:cool:.
    Any reason they didn’t this time :whistle:?
    edthefox5 likes this.
  4. golfmk681
    264
    105
    los angeles, ca
    Hmmm not sure do you have to pay extra for that?
  5. douglasjre
    douglasjre Senior Member
    2,177
    717
    Null, NL
    If you do 10k mile oil changes u won't have to write it down. You'll have easy reference. Your choice.
    Your motor sounds happy. Nice work. What was ur oci interval for the life of the car?
  6. TomB985
    TomB985 Member
    137
    68
    Isanti, MN
    They charge extra to run TBN. I believe it's another $10-15 last I had one run.
  7. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Knowing the acidity or basicity is a key component of the analysis IMO.
    I know @edthefox5 would agree too.
  8. Mendel Leisk
    41,406
    And that's not showing? That would be indicated by "PH"?
    I'll just keep to my Canadian 3rd gen schedule, slam in 4.2 litres every 6 months, won't divulge the kms. :whistle:
    TomB985 likes this.
  9. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    5? :D
    edthefox5 and Mendel Leisk like this.
  10. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Maybe i missed it, but I do not see it listed in the Blackstone screen shot in post 1:cool:.
  11. Mendel Leisk
    41,406
    Uhoh, don't tell anyone:
    And that's kms....
    #11 Mendel Leisk, Feb 19, 2019
    Skibob likes this.
  12. Skibob
    2,912
    1,502
    Northern California
    So about 4000 miles a year.
