New Cabin Air Filter, Blower motor service, and Engine Filter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Joe Wall, Feb 16, 2019.
  1. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    You could buy one then compare it to the Toyota one. That’s what I did with my Aisin clutch plate. Exact same part.
    That would require work on your part though. :(
    And where did you get 30 dollars from? I can get an air filter for 14.36 + tax and a cabin filter for 15.09 + tax on the way home at the dealer today.
    #21 Skibob, Feb 20, 2019
    51,895
    A visual comparison may not tell the whole story
  3. Skibob
    2,912
    1,502
    Northern California
    If the numbers are the same it does. In fact for the Aisin water pump for my 4 runner they grind off the Toyota name but you can still see part of it. Why do you even post here? You know near nothing about cars.
    jb in NE likes this.
  4. bisco
    51,895
    Boredom. Why do you?
  5. Skibob
    2,912
    1,502
    Northern California
    Because unlike you I actually repair cars. My own cars. Everyone always wanted me to fix their cars because I do a good job but that gets old after a while.
  6. Mendel Leisk
    41,402
    Mmmmmm :rolleyes:
    edthefox5 and bisco like this.
  7. Stevewoods
    Stevewoods Senior Member
    659
    1,130
    Seattle, WA
    cause rock auto says so.....:whistle:
  8. Skibob
    2,912
    1,502
    Northern California
    Actually we have been thru it in another thread. But Bisco tends to forget things. :rolleyes:
    Stevewoods likes this.
  9. bisco
    51,895
    i can't remember what i had for breakfast
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    It’s impregnated with charcoal it’s not loose and even if ripped no mess.
    Zeppo Shanski and Skibob like this.
  11. Classic Car Guy
    Classic Car Guy Active Member
    414
    119
    Northwest, USA
    ....... Oops sorry
    Patrick just s a quick left turn. You know a place where I can get a front bumper for 2018 Prius 2 model #1223A? or whatever you call it bumper shell? Its factory color blizzard pearl. I need to replace it. If you know where I can get the bumper that's painted. I don't know if aftermarket will fit like a glove. Basically I want to get it done the right way.
    Thanks,
    Joe
  12. Patrick Wong
    18,204
    6,505
    $166.32 plus shipping here. You will have to get the cover painted locally.
    Bumper & Components - Front for 2018 Toyota Prius | AutoNation Toyota Gulf Freeway
  13. Classic Car Guy
    414
    119
    Northwest, USA
    Hi Patrick,
    Okay looks great. I 'll order this one and thank you so much.
    Joe
  14. johnjohnchu
    johnjohnchu Active Member
    211
    104
    I always make my own cabin filter from regular home a/c filter elements. It works well and is also very economical.
  15. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Interesting. Doing something like that never crossed my mind.
    Is there a reason why you chose the home HVAC filters w/ the wires? Did you try HVAC filters w/o the wires, but they became problematic and got sucked into the blower motor, or something like that?
  16. johnjohnchu
    211
    104
    There is no reason at all. I just happen to have these filters on hand. These wires seem to be real strong and will not come apart from the filter elements.
  17. Fyretuck
    Fyretuck Junior Member
    Lyons, OR
    I have purchased these:
    2 Pack - EPAuto CP285 (CF10285)...
    EPAuto GP741 (CA10741)...
    I live in the countryside and have rodents too. You replace the filters more often, due to the rodents. Mike don’t like fabric softener dryer sheets. I put one in my lower glove box and they don't come around as often.
    To get the blowout motor unmounted, I use a finger ratchet wheel for getting to the mounting screws.
  18. Fyretuck
    Lyons, OR
    Leave fabric softener dryer sheets in the glove box, under the front seats, under the rear seat, in the rear cargo area, and any other place you see tracks.
  19. edthefox5
    10,096
    4,833
    Clearwater, Florida
    I don’t have rodents.
  20. Mendel Leisk
    41,402
    Take off the wipers and cowl, install a 1/4" mesh grill (galvanized steel rodent/bird mesh, available at any hardware store) over the cabin air intake. Put the same over the engine air intake too; I've read they'll take up residence in the air box as well.
    Fyretuck and Skibob like this.
