Rear Hatch Rattle
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by renzo750, Feb 24, 2019.
  1. renzo750
    renzo750 Junior Member
    25
    27
    St. Paul, MN
    I have been dealing with this for 14 months and 27,000 miles...on a 2017 4 that I took delivery on 12/20/18.
    The sound is coming from the right rear (or at times sounds like the rear seat)
    I've had the shock nuts done per the TSB,
    Techs have insulated the panels in back corners and the bumper, and chased outside trim pieces (as have I).
    I've spent hours and hours trying to pin this down, I know my way around a vehicle, it's been back to the dealer multiple times and they have spent hours chasing it as well - I(we) thought rear seat arm rest, hatch cover rattle, stowed under rear floor stuff...what have you ... it's been a monster frustration has almost pushed me to dumping the car..
    Finally I removed everything I could, rode in the back and concluded that the rattle was coming from behind the right rear interior panel. I put an "X" in tape on the panel and took it back to the dealer for the 5th or 6th time.
    Dealer - quoting service order "Rattle upon driving internal baffle issue with right rear shock, replaced shock..."
    482201 Replaced Right Rear Shock
    48530-80788 Absorber set shock
    48750-47020 support assy RR sus
    94130-61200 Nut
    90201-16039 Washer Plate
    90109-A0066 Bolt
    Still do not have it - I can give the rear bumper a hard burst - push down and I can hear the rattle behind the right rear inner plastic wall - sounds like a wire connector or something banging around about half way between the wheel and rear of the car.
    At times it still sounds like the rear center arm rest plastic, but I've drove with a broom handle pushing on the arm rest to no avail. And a tech riding in the rear seat also thought it was behind him and possibly in the hatch trim.
    I've build and restored cars and motorcycles over my entire life - this car was to be my daily wheels to take me into retirement - I'm so frustrated. I have a 2004 MB SLK320 hardtop convertible with over a 100K on it that makes this car feel like a bucket of bolts - my Gen 3's where far more solid feeling than this Gen IV. I'm sick of having to turn my hearing aids off and crank my JBL to ride in this car - makes it tough to talk to passengers :)
    I have to say the dealer has been working hard to get this resolved. After the last failure to get it sorted a tech, myself, and the service manager all went for a ride - I am happy to say that they fully agree that the car has an unacceptable rattle coming form the rear hatch...this week we have a regional specialist coming up from Chicago ..I'm at my wits end - I sure hope we get somewhere...
    I'll follow up after my next meeting on Thursday - in the meantime I'd love to hear from anyone that is having, or better yet, solved this issue.
    ice9 and fsab888 like this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Is the hatch door closing tightly? I've had that on other hatches - my PRIUS is quiet.
    krmcg likes this.
  3. fsab888
    fsab888 Junior Member
    Oman
    Two Eco
    same issue I have in my 2016 prius echo 4.... I have noise from right rear corner. I tried to remove everything (plastics rear door plastic covers etc..... still noise coming when vibration occurs.... annoying me...
    SM-G955F ?
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Could it be the sensor in the bumper ?
  5. renzo750
    25
    27
    St. Paul, MN
    Yes - the hatch closes solid with no play or movement. Thanks
  6. renzo750
    25
    27
    St. Paul, MN
    I like that suggestion, worth a look - thank you.
  7. renzo750
    25
    27
    St. Paul, MN
    Well - it appears we have it!
    The tech from Chicago and the local service manager more or less had it figured out when I showed up - we went for a brief drive to confirm. Solution (and tested on a road in my neighborhood that was driving me nuts) was to replace the hatch stoppers and cushions.
    The new stoppers are much softer - the hard rubber of the old stoppers, even though the hatch felt tight, would rattle against the frame. Quoting the service order:
    642991 Replaced Rear Gate Bump Stops:
    2- 27293-47031 Cushion, Back Door S
    2-67281-47020 Stopper, Back Door
    #7 renzo750, Feb 28, 2019
    thomassster likes this.
  8. EdW
    EdW Junior Member
    22
    Pittsburgh, PA
    What kind of sound was it making? I have a '17 Prime that has had a metallic click/tick sound from this the right rear of my car since it was new. I wonder if I might be having the same problem? I've had it at the dealer so many times for the issue that I kind of just gave up on it.
    I have felt tape over the tops of those bumpers, did you think yours were vibrating against the metal body or just the hatch itself? Thanks in advance!
  9. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    Same issue, i put the soft side of some heavy duty Velcro over the bumpers and noise is gone.
  10. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    Tried this but still have rattling noise in the rear part of car. Mostly on rear driver's side when hitting a bump. Maybe I might try to go to the dealer and hopefully they can figure it out.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Sounds like you may have the loose shocker nut syndrome, I think there was a recall for it in the US.
  12. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    I have a Prius Prime and I think that recall is only for regular Prius? Planning on bringing it to the dealer later today and see if they can figure it out. Thanks.
  13. stemc
    stemc New Member
    san diego, ca
    I had the exact same issue. The problem was the driver's side rear shock. They replaced it, but I suspect it was merely loose. The problem is now gone! It was driving me crazy
    krmcg and utsug like this.
  14. Robert J. Sexton
    Robert J. Sexton New Member
    Two Eco
    Bolt had come loose on passenger side back shock. Dealer replaced both rear shocks. Rattling has stopped. Good luck.
  15. james909
    james909 Member
    107
    Leeds, U.K
    Hi. I have this noise on my gen 2. Wondered if it was the same noise. It comes from the hatch behind the passenger rear seat nearest the kerb (we drive on the left) when that wheel goes over potholes.
