Bluetooth in car dual radio adaptor-anyone tried this?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Rickl55, Feb 28, 2019.
  1. Rickl55
    Rickl55 Junior Member
    Western NY
  2. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    It will work. But you may/might get noise, especially if you charge your phone while using it. And the price is obscene for a no-name brand.
    Go to Amazon and buy the MPOW MBR2. It's a known brand and comes with a noise isolator, which will eliminate weird noises while charging. Also, it's $3 cheaper.
  3. Rickl55
    Western NY
    I will give it a try. Just ordered it. Thanks.
    egg_salad likes this.
  4. Rickl55
    Western NY
  5. Rickl55
    Western NY
    Wow. This device is amazing. Once I installed it it synced right away. I can now play music and podcasts static free. No more cable from the AUX port running to the phone. I can still use the steering wheel controls to answer a call OR the button that comes with the kit! Thank you for the recommendation!
  6. hyojyang88
    hyojyang88 New Member
    NOVA
    Are you able to use your steering wheel controls to control volume or change tracks?
  7. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    I use my Ray Con ear buds
    iPhone ?
  8. Rickl55
    Western NY
    I can use the steering wheel volume controls but to change tracks must use the device.
    hyojyang88 likes this.
  9. PAUL SCHULTZ
    PAUL SCHULTZ Member
    103
    66
    Michigan
    I have this item and agree it is a nice addition. I also purchased a AC/heat vent mounted magnetic wireless charging pad for my cell phone. I added the metallic adhesive mount to the back of the phone case. Now, I hop in the car, pop the phone onto the mount and it starts charging. I have my phone set to launch Android Auto when it connects to the bluetooth so AA comes on and I can play music, audiobooks, podcasts, etc while on my 60 mile work commute.
    Paul
