Car locator for Prius Prime Plus 2018: don't remember where parked
Discussion in 'Prime Main Forum (2017-2022)' started by Chris MM, Feb 28, 2019.
  1. Chris MM
    Chris MM Junior Member
    2018 Prius Prime
    We parked in a huge parking lot and couldn't find our car coming back. Panic button didn't work. Then we parked in the city and went to an event. Then afterwards spent quite some time trying to find our car. I wonder, since the Prius Prime has GPS, can we utilize that to locate the car? Like an APP which shows us where the car is?
  2. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Pretty sure you'd need the Advanced Trim Level.
    I found the Prime App Car Locator gives you a ball park location not
    a specific parking spot but certainly within a few rows in a parking lot.
  3. bisco
    52,417
    Saw a lady taking some pics of her cars location on the way out of a uge parking garage, thought it was a good idea.
    Of course, my wife thought it was because she would be falling down drunk on the way back
  4. Chris MM
    2018 Prius Prime
    Thanks! We have the Prius Prime Plus. The car has GPS system. Technically we should be able to access that from our Android phone. I wonder if there is any way to utilize this.
  5. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    You need the Telematics piece (Verizon Cellular) to report the car’s location. Advanced only.
  6. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    there are apps for your phone that record the gps location when a blue tooth connection to your car is broken. that way you can navigate to where you where when your car was shut off. obviously you need to have your phone paired to the car for it to work.
    someone will have to look it up though. I don't have it on my phone since I have the advanced app which works pretty good for this.
    fuzzy1 and jerrymildred like this.
  7. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    mountaineer and Curlyone like this.
  8. bamike
    bamike Junior Member
    59
    32
    DC
    2018 Prius Prime
    Google maps gives you the option of saving where you parked on your phone. It's free.
  9. benagi
    benagi Active Member
    525
    280
    Utah
    I have 2 apps on my iphone that show where my car is parked. Maps & Google maps are the 2 apps. I just used both and they both show the car is at my house. They get triggered any time the car is turned off and locks in your cars location.
    Chris MM, ardashev and citiprius like this.
  10. CharlesH
    2,797
    1,165
    Roseville, CA
    Just a little more detail: while the GPS system in the car may know where it is, only the Advanced trim has the built-in cell phone to allow you to access that information from the Internet. This is the same system that provides emergency response comparable to GM OnStar. So on other trims, other solutions as have been mentioned are needed to locate your car.
  11. Chris MM
    2018 Prius Prime
    WOW. This is very helpful!. Many thanks! I need to check if it works with Android as well. Why wouldn't it?
    benagi likes this.
  12. Chris MM
    2018 Prius Prime
  13. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Glad you found out about the apps. They are handy. They just note your location when they lose bluetooth contact with the car. Not spot on accurate, but they'll usually get you close enough to reach the car with your fob.
  14. bamike
    59
    32
    DC
    2018 Prius Prime
    Android is Google's software, yes it will work on Android. When I navigate somewhere with google maps, once I have arrived and the navigation is complete, it asks me do I want to save my parking. Also, if you press and hold on the map, you can save any location.
    Find & save parking locations - Android - Google Maps Help
  15. Ginswheels
    Ginswheels Junior Member
    Driggs l D
    There are apps for apple phones that will GPS mark where you parked your car and you can use the map to find it again... I am sure android have the same thing. You might have to remember to keep it turned on, on your phone. It does not require any thing from the car.
  16. jerrymildred
    11,517
    14,158
    Tampa, FL
    No need for another app with iPhone. It's baked in. Just open Apple Maps.
  17. ColoradoBoo
    ColoradoBoo Senior Member
    1,275
    881
    Monument, Colorado USA
    Oh no...yes definitely use one of the apps suggested. I used the Google app on my iPhone when I park at the Air Force Football games out in the field...directs me straight to the car when walking. (Especially helpful when it's a night game...not many lights out in the dark field.)
  18. fuzzy1
    10,603
    I think something is baked in to Google Maps on Android too, even without Bluetooth. I have Bluetooth turned off on both car and phone ends, yet the phone has shown me a parking location a time or two without me recording it. But it isn't something I look for or use regularly, so haven't dug into the details.
    jerrymildred likes this.
  19. jerrymildred
    11,517
    14,158
    Tampa, FL
    Same here. I haven't wished for help to find my car since I got turned around in a hospital parking garage that was under repair about 8 years ago.
    fuzzy1 likes this.
  20. fuzzy1
    10,603
    I have 'lost' my parked car a bit more often than that, but always just briefly. My time spent looking for it has been considerably less than the time spent trying to figure out and troubleshoot mobile phone app features and connection problems.
