Prius brake pads
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2013 Prius, Feb 28, 2019.
  1. 2013 Prius
    2013 Prius New Member
    Delray
    I brought my 2013 Prius that has 64k miles into a new Toyota dealership for a recall and software update to address the recall. Toyota told me my brakes were 2/32 and I needed new pads. He also told me they would resurface the rotors. They quoted me $500 total for the front and back brake pads and resurfacing of the rotors front and back. This is a new dealership for me as I moved from another state.
    I just came back from a second opinion at a non Toyota facility. They tried to tell me not only did I need brake pads but new rotors and it would be $700 total front and back. I told them I'd gone to the Toyota dealership and what had been told to me. This place told me that you can't resurface rotors because it'll thin them and then I will need new rotors down the line both front and back. I'm totally confused as to what to do. Pls advise..Thanks
  2. tweedle99
    tweedle99 Member
    124
    69
    Round Rock, TX
    That's pretty low miles to be replacing brake pads unless previous owner was racing the prius. Most ppl can go close to 150k before replacing them. I went 140k after dealer said my brake was in need of new pads. That weekend, I took it apart and there was plenty of pads left. I went ahead and replaced the pads anyway since i already took them apart.
    Why do they need to be resurface? Are there any visible grooves? pulsating pedal?
  3. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    I really depends on your driving habit. My 2007 Gen-2 Prius, I sold it last year with 235K on it. But it is still on the original brake pads with 1/2 left.
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Go with the first place
  5. Mendel Leisk
    41,824
    The rotor thickness runout specs, plus how to measure both, are in the attachment. If you get yourself a 0~25 mm micrometer, and a dial indicator with magnetic base, you can see for yourself if they are blowing smoke. Both those items will set you back maybe $50~60.
    If time is short, I would just get them to replace the pads. Just for giggles ask them what thickness they measured on the rotors, and what the runout numbers were.
    Or if you DIY the replacement, either front or rear pad sets through parts department would be about $100. Be careful with the rears though: it's very important to orient the caliper piston per the pic in the attachment.
    And with either front or rear pad replacement: disconnect the negative battery cable before commencing, and when the brake is reasembled, press the brake pedal multiple multiple times, to ensure everything is well seated. Only then reconnect the battery. Take a short test drive, being very gentle on the brakes. Do not use the park brake at all. Upon return, press/release the parking brake several times, then raise the rear of car and verify the wheels spin relatively free with a push, will go one or two revolutions.
    This statement is very likely true:
    Rarely if ever have I found brake rotors out of spec; the dealerships way overdo the the resurfacing and/or replacement of rotors.
    Robert Holt likes this.
  6. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    New pads should always go with new rotors or resurfaced rotors.
  7. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Those numbers are pretty steep. Do yourself a huge favor and take the time to learn how to perform basic maintenance items for your car. You will save a ton of money for your Prius and for all future vehicles to come.
    To save the most money here, first measure the thickness of your rotors. The minimum thickness should be embossed somewhere on the rotor. If enough thickness, then find a shop/gas station that resurfaces rotors. Cheapest I know of in my area is $15/rotor. Then head to Oreilly or Autozone to get new pads. Shouldn't run you more than $60. Total cost $120.
  8. ChapmanF
    18,454
    Source?
    If the rotors are glazed (shiny, glass-like surface), that can be fixed by hand with a couple minutes and 150 grit sandpaper. (Source: Ford 1984 Bronco II shop manual. They did not recommend a rotor lathe or replacement for any reason except the rotor condition requiring it.) Wet sanding seems to me to work best.
    Rotor condition requiring a lathe or replacement would be deep scoring, pitting/deep rust, (edit: excessive runout), thickness limit. That kind of thing.
    #8 ChapmanF, Mar 1, 2019
    RMB, Robert Holt and Mendel Leisk like this.
  9. Mendel Leisk
    41,824
    Toyota doesn't say that; just says to inspect rotor surface for scoring, check against thickness and runout specs. I've been changing pads for about 40 years on Hondas, never changed rotors. In one instance I should have: the rotor did get down to mininum thickness, and cracked. But if the rotor is well within specs, no reason to do that; it's just a dealership's tale.
  10. bamike
    bamike Junior Member
    59
    32
    DC
    2018 Prius Prime
    #10 bamike, Mar 1, 2019
  11. Mendel Leisk
    41,824
    One thing with deals like that, they're either going to try to upsell you like crazy, or are going to go very fast, will not clean/lube components at all, will not relube the caliper pins. The pads up here are typically just over $100 CDN, and replacement shims maybe $15. So in the States maybe $80 for pads/shims. That's front or rear. There's no free lunch.
  12. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,720
    1,761
    Bay Area
    I would recommend when changing the brake pads to turn/cut the rotors or replace them. I’ve had experience just replacing the brake pads without work on the rotors that the pulsation from the rotors will come back. Changing out the brake pads without cutting the rotors (if minimum thickness is available) is just lazy work, or replacing them (if minimum thickness is beyond cutting). I’ve did that before and won’t be doing it ever again, so do it right the first time or you’ll end up redoing the process again.
    As for changing out the brake pads and cutting the rotors for 500$, if you can DIY, you can save about 300$ since pads and rotors aren’t expensive parts, it’s more on the labor that they’re charging you. The labor cost is around 2-3 hrs so they’re charging you 100$ or 110$ per hr.
  13. bisco
    52,286
    The pads have a noisemaker that you can hear when they need replacing. Ignore both shops
  14. Mendel Leisk
    41,824
    2/32" remaining depth might be slightly too much for the noise maker; it maybe commences around 1 mm. Just taking a look for yourself is always good, whichever way it slices.
  15. bisco
    52,286
    If you’re so inclined
  16. ChapmanF
    18,454
    Changing the pads without deglazing and inspecting the rotors, including slapping a dial indicator on and checking the runout, I would agree is lazy work.
    Unconditionally machining or replacing the rotors, to spare the small effort of inspecting them to see if they need it, I would submit is also lazy work, leading to unnecessary material removal, shortened life, premature replacement ... and (depending on what they're replaced with), a lot of Prii driving around on dime-store replacement rotors.
  17. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    If you think that’s lazy work, theres of plenty of people here who never checks their engine oil sticks. What would you consider them then? :ROFLMAO:
    NutzAboutBolts, Raytheeagle and RMB like this.
  18. ChapmanF
    18,454
    Essential supporters of the secondary Prius engine market.
    NutzAboutBolts likes this.
  19. bisco
    52,286
  20. Raidin
    Raidin Active Member
    238
    183
    Houston, TX
    Try visiting RepairPal.com. Put in your car, zip code, and what work you need, and it will give you an estimate of how much the work should cost in your area, so you can compare it to the shop. It can also recommend shops in your area based on reviews and their own certifications.
    Raytheeagle likes this.
