ECM update???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by monash, Mar 5, 2019.
  1. monash
    monash Junior Member
    Danbury, CT
    what is the ECM
    52,275
    engine control module
    Elektroingenieur likes this.
  3. gliderman
    gliderman Active Member
    751
    225
    Not where I come from, it's Electronic Countermeasures. :D
    Actually I think the term used by Toyota is Electronic Control Module since the Prius is just a computer that burns gas and there are ECM's in everything. Not just engine control.
  4. bisco
    52,275
    maybe it's the ecm update
  5. Elektroingenieur
    2,515
    3,287
    Three Touring
    In Toyota’s English-language service documentation (more info), the generic term is ECU, Electronic Control Unit; the ECM, Engine Control Module, is the ECU for the engine.
    gliderman likes this.
  6. monash
    Danbury, CT
    thank you , but should we have to pay for any the update or usually free if any issue occurs.
    #6 monash, Mar 5, 2019
  7. Elektroingenieur
    2,515
    3,287
    Three Touring
    Unlike some other automakers, Toyota doesn’t impose a per-vehicle charge for updated ECU software, and most of the updates can be downloaded from techinfo.toyota.com with a Professional Diagnostic subscription, from $65. If you’re considering a do-it-yourself update, be sure to read and follow T-SB-0134-16 Rev1, “Techstream ECU Flash Reprogramming Procedure” (PDF).
    For updates installed by Toyota dealers, the cost, if any, depends on the reason for the update. Safety recalls, such as the update for the Power Management Control ECU in recall J0V, are done at no charge to the owner. The same is usually true for service campaigns, at least until the campaign expiration date, if any.
    Updates announced only in technical service bulletins, such as the ECM update in T-SB-0103-12, “MIL ‘ON’ DTC P2111 and P0A0F After Cold Soak,” generally don’t have any special coverage, beyond the warranties included with the new vehicle. If the parts involved are still covered, the update is a no-charge warranty repair; after the warranty ends, the owner would have to pay for the dealer’s labor. Keep in mind that these updates usually apply only to vehicles that have the specific problem described in the service bulletin.
