Tire Repair Kit ... Dealer admonishment?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by apalapala, Mar 5, 2019.
  1. Salamander_King
    Salamander_King Senior Member
    11,023
    8,958
    New England
    Looks like they just cleaned TPMS sensor and re-installed it. Let us know if it fails in short time. If it does, it sure means it is not compatible with Goo Toyota provides.
  2. Prodigyplace
    12,625
    11,807
    Central Virginia
    ... and should therefore be covered under warranty.
  3. Salamander_King
    11,023
    8,958
    New England
    For OP's case maybe, but if it happens outside of warranty period, I doubt they will cover it.
  4. Prodigyplace
    12,625
    11,807
    Central Virginia
    True, but they should since the goop is obviously defective.
    Salamander_King likes this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Goop is only has a shelf life of 5 years.
  6. padroo
    padroo Senior Member
    2,763
    2,252
    I have never used Goop in a a tire but I used this stuff in my wife's lawnmower tire that has leaked for years and just a little of it sealed it.
    The only trouble with this is it does not inflate the tire, you still need an air compressor.
    I hope I never have to use it on a car tire but it does work.
    http://www.amazon.com/TireJect-Tire-Sealant-Kit-prevent/dp/B07D5M1MXJ/ref=as_li_ss_tl?keywords=tireject&qid=1551848618&s=automotive&sr=1-1&th=1&linkCode=sl1&tag=sixtyfivefo05-20&linkId=4fb775d447c51393bcea7aa6e8c244b3&language=en_US
  7. bamike
    bamike Junior Member
    59
    32
    DC
    2018 Prius Prime
    There is no reason to use the goop when you can have the car towed for free. Just have it towed to any tire shop, or if Toyota demands you tow it to a dealer do that.
    It will still be cheaper to buy a tire from a dealer (many of them price match) than to pay the labor to have all that junk you put in the tire cleaned out. Most cases the tire could have been patched for $20 if you hadn't put in the chemical.
    I would only use the goop if it was life or death, otherwise, call a flatbed tow truck.
  8. Prodigyplace
    12,625
    11,807
    Central Virginia
    1. Some our cars are out of warranty.
    2. Some of us do not trust our Toyota dealers.
    3. The tire warranty is from the tire manufacturer, (Bridgestone, in my case) not Toyota. That is clear in the documentation you received with the car.
    4. Since the tire warranty is not from Toyota why would towing be free?
  9. RRxing
    RRxing Senior Member
    2,553
    1,826
    NEPA
    Or even "definite." ;)
    padroo and Prodigyplace like this.
  10. Prodigyplace
    12,625
    11,807
    Central Virginia
    definitely :ROFLMAO::ROFLMAO::ROFLMAO:
    krmcg likes this.
  11. bamike
    59
    32
    DC
    2018 Prius Prime
    Do you have roadside assistance as part of your insurance company? Towing is free at least for me, up to 9 miles. Roadside assistance including towing costs me $2.50 every 6 months from Geico. The cost goes up to around 7 dollars for a much older car.
    Also, during the first 2 years/25k miles Toyota offers free towing to the nearest dealer. https://www.toyota.com/content/ebrochure/toyotacare.pdf
  12. Prodigyplace
    12,625
    11,807
    Central Virginia
    So you get free towing to the dealer to pay for a tire repair or pay for towing to a tire dealer hoping for a warranty repair.
    Either way, it is not free.
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Yep.
    My concern would be that it does seem they just cleaned the sensor and reinstalled. Then are saying they aren't sure how damaged the sensor might be.
    Also, upwards of $300 to replace one tire seems very expensive.
  14. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    This will just go on like an oil thread, so use the goop, use your phone, install/use a spare or buy a different car. The decision/choice is made by the owner and all designated drivers live with it.
  15. apalapala
    apalapala Junior Member
    24
    31
    Tampa, FL
    Four Touring
    I actually called Toyota's roadside assistance. They said it would take 35 minutes to get someone out to me. Sent me the confirmation, and they were sending a locksmith, not a tow truck. By the time I realized, I had already changed out to my spare. I should have called AAA.
    Side note: I think relying on towing only isn't the best if you're out in the middle of nowhere in the middle of the night.
    #35 apalapala, Mar 7, 2019
    Prodigyplace likes this.
  16. apalapala
    24
    31
    Tampa, FL
    Four Touring
    That makes more sense. Thanks!
  17. Prodigyplace
    12,625
    11,807
    Central Virginia
    Unfortunately I work at a university. I automatically figured it out because typing the wrong word is rampant here at times.
  18. Mendel Leisk
    41,808
    If you're going somewhere, with a spare, get a flat, odds are very good you'll get to your destination, with little interruption. With a tow instead, your life is going to be very disrupted.
    #38 Mendel Leisk, Mar 7, 2019
    kithmo, frodoz737 and Prodigyplace like this.
  19. Prodigyplace
    12,625
    11,807
    Central Virginia
    Even on a long trip. at least the spare can take you to where you can get help.
    My son had a blowout on an interstate with his Prius v during a long trip home from a dog show. The spare got him to Walmart where they were able to replace the tire so he could make it home. He then replaced all 4 tires with better new ones since the other old tires were worn anyway.
    kithmo and Mendel Leisk like this.
  20. xerox6135
    xerox6135 Member
    170
    94
    michigan
    No place for a spare I buy different car
