Thermostat (3rd gen) answers !
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ben Schneider, Mar 7, 2019.
  1. Ben Schneider
    Ben Schneider Junior Member
    central florida
    so very little info on thermostats !
    seems after a lot of looking, that the oem temp is 180 ?
    after reading reviews, seems most thermostat manufacturers don't even get 4 out of 5 stars
    who manufactures prius thermostat ?
    is it aisin ?
    thermostat is located literally on the opposite side of the water pump mount (wish i had known this before changing, more coolant to waste)
    here is the first video i found on how to change
    anyone have experience with motorad, gates, replacement brands of thermostats ?
  2. Ben Schneider
    central florida
  3. Ben Schneider
    central florida
    frustrating that thermostat is an expensive assembly and not on top of the engine like most cars
  4. ChapmanF
    18,555
    Right in the repair manual, open between 80 and 84 C (176 to 183 F), lift by 10 to 14 mm at 95 C (203 F), should be fully closed below 77 C (171 F). More information than that might be harder to find. :)
    They're nearly bulletproof. Expanding wax opens them, a big spring closes them. To get one to jam open, you'd need corrosion or grot stuck in it, neither of which should happen if the coolant is changed often enough to keep the corrosion inhibitors active. Only way to make one fail closed is to severely overheat the engine some other way until the wax blows out. Other than those failure modes, who ever needs to replace one?
    Robert Holt likes this.
  5. Ben Schneider
    central florida
    much appreciated...
    changed coolant a few times in the last few weeks... some white translucent chips were in the second, looked like coconut chips... i hope that is not wax, will post photo in next post
  6. Ben Schneider
    central florida
    White chips
  7. ChapmanF
    18,555
    Corrosion products of aluminum in a liquid can have that white crystally/flaky look too. Had it gone a long time without a coolant change?
  8. Ben Schneider
    central florida
    appreciated. been quite a long drive.
  9. Lino
    Lino Member
    61
    Why would you want to change the thermostat, my experience with thermostats is they stick closed and engine gets hot very fast, if the temperature is maintaining around 190, then there is nothing wrong with the thermostat, mine is pushing 290 k
  10. Ben Schneider
    central florida
    it's pretty common practice to change thermostat every 50 or 100k... since i changed the water pump it's been running a few degrees hotter than it did before (i also changed pcv valve if that is any factor)
  11. Lino
    Lino Member
    61
    Even if a thermostat cost the price of a beer, your wasting your money when you could enjoy a cold beer instead
    Rebound likes this.
  12. Lino
    Lino Member
    61
    Revived from the dead, still an issue that might help others.
    Well the thermostat has stuck closed on my Prius a few times, this happens only in the first couple of miles when it happens, luckily I have the Ultragauge 2 on all my cars, this morning it got to 217 and my wife pulled over on side of freeway before any damage, then after sitting a little it opens up and works fine.
    I did not have the Ultragauge on my last engine I did not think I overheated it, but now I have my doubts.
    This has happened to my wife a few times in the last year 3-5 times too many, Ultragauge is cheap insurance thanks to the alarm I hope to never do a head gasket.
    As I stated before this is how a thermostat acts, once they open they work fine, your car doesn’t run good for sometime on a trip then all the sudden your thermostat goes bad, once they are open there will not be any thermostat issue.
    Buy yourself an Ultragauge you will not regret it, I own 3 and have told some co-workers about them and never heard a complaint.
    They will save your car as lost as the driver knows what to do when temperature goes high.
    mjoo likes this.
  13. Too Old to Clean EGR
    Too Old to Clean EGR Junior Member
    Thermostats are more reliable than they used to be, but they are far from "bulletproof." Better modern coolant chemistry probably helps but in years past with the old glycol type it was not unusual for a thermostat to fail within 10 years or so. I have seen them fail on newer, well maintained vehicles but not as often.
  14. ChapmanF
    18,555
    Which way?
    Stant, prominent maker of thermostats, has literature explaining how a fail-closed situation can result from overheating that ruptures the structure and blows the wax out. They don't list other causes for that failure mode, that I've seen. If the wax hasn't been blown out, its expansion is a more-or-less irresistible force.
    Fail-open can be more common, as it requires only that the spring hasn't strength to re-close the stat as the wax cools.
  15. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    What's considered overheating for a gen 3 Pruis? Also at what temperature does the read overheat light go on?
  16. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Anyone have any answers?
  17. ChapmanF
    18,555
    Gen 3 has two coolant temperature sensors, one in the cylinder head and wired to the ECM, one in the hose returning from the exhaust heat recovery system and wired straight to the combination meter.
    Either one can make the red-thermometer light come on:
    The one in the hose will make the light come on at 120 ℃ (248 ℉).
    I haven't checked at what temperature ECM will make the light come on, based on the sensor in the cylinder head. I wouldn't be surprised if that's the same threshold, 120 ℃, but I haven't seen anyone actually check that the way I did with the other sensor.
    Note that if the ECM has given a code for a water pump problem, it has a lower alarm point, where it will flat-out stop the engine at 105 ℃. The car remains powered up and can do electric driving (for the usual short distance and limited speed). You don't see a temperature light then (because this temperature is lower than where that light comes on); you'll just see the warning triangle and wonder why you have only EV driving. (Ok, you won't really wonder, because you will have had the check-engine light ever since the pump problem was discovered, and if you had read the codes then you would have known it was a water pump problem, and you would have taken care of it.) Moral: don't procrastinate when you see a water pump code.
    Because the thermostat opens at 80 to 84 ℃, and the fans come on around 95 ℃, and I have a ScanGauge on my dash at all times, I seldom see the temperature above 90 ℃, and scarcely ever see it even nearing 100 ℃. If I ever saw it that high, I would already be wondering what the explanation was, and not waiting for a light to come on.
    Dave1UK and Dusttttt like this.
  18. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Great thanks very much Chapman. I noticed yesterday while driving up a very steep hill that the coolant temp sensor (hose returning from the exhaust heat recovery system) reached about 100C (212F). Normal driving, the temp stayed around 87C (189F). I plan to replace the water pump with OEM Aisin this week and hopefully the temp won't get up that high after replacement. Will post update.
  19. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
  20. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Ok upate time: I replaced the water pump and thermostat and thank God no more overheating, even going up a long steep grade. Temp reached a max of about 194F. then stayed around 189-190 going 75mph on flat with AC on. Next project is to clean EGR and install a catch can!
    #19 AmazingFacts, Aug 24, 2021
  21. Mendel Leisk
    41,911
    How many miles on it? Info link in my signature.
    AmazingFacts likes this.
