widest tire you can run
Discussion in 'Gen 2 Prius Accessories & Modifications' started by tunerPRIUS, Apr 21, 2013.
  1. tunerPRIUS
    tunerPRIUS Junior Member
    37
    Liverpool, New York
    Yes I need to bring the rear out an inch to be flush....thats what 20mm spacers? Prob need longer lugs too :(
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Anything longer than 5mm you will want longer studs. I've been running a temporary generic 8mm w/o longer studs up front and 20mm (built in studs) in the rear for about 5000 miles and the lug nuts are are good and tight with no issues of vibration...but I wouldn't recommend it long term.
    I'm going to a 15mm up front and 30mm in the back soon and I will need to either replace the studs or get an spacer that
    Looks like this:
    vs
    much less work than replacing the studs with longer ones. The Touring 16" wheel has a space where the spacer with the built in studs will work.
    Just make sure you get really good quality material.. grade 8 studs.
  3. tunerPRIUS
    37
    Liverpool, New York
    Yes they perform equally as kyb which is not an impressive strut in the first place
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    So its decent oem replacement. Thanks!
  5. Joseph T.
    Joseph T. New Member
    San Jose, CA.
    Do you think I can put 215x55x17 on 2013 Prius ?
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    this Is the gen 2 forum. you should ask in the gen 3 forum. might be too tall, but width should be ok.
    SFO likes this.
