Donut size spare for Prius prime
Discussion in 'Prime Accessories and Modifications' started by Bluebells2, Apr 15, 2018.
  1. Bluebells2
    Bluebells2 Junior Member
    46
    Silver Spring, MD
    What is the Donut size spare for Prius prime. I see the real size in the owners manual but don’t see a donut size correlation . After having a vehicle tag screw in my tire before I even drove off the lot of getting the car I want to make sure I get a doughnut. Therefore looking for the size to buy for the doughnut for the Prius prime I know that the car doesn’t come with that item I found that out the first day owned it. Want to buy a donut so I’m safe .
    #1 Bluebells2, Apr 15, 2018
  2. Bluebells2
    46
    Silver Spring, MD
    Will the spare tire from my Prius V Donut Yokohama factory-issued spare, that came with the car fit the Prius prime. Tires on both the Prius are P195/65R15. This donut size for the V is T135-80-D16 101M. The Prime does not give a donut size equivalent and Toyota has no part for it.
  3. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Unfortunately your Prius v donut wheel Won't work because the bolt pattern is to big at 5x114.
    The 135/80-16 tire size is the correct diameter at ~24.8", you would just need the correct 16x4" 5x100 steel wheel to make it work.
    Search Ebay, I'm seeing alot of new/used Toyota donuts for sale in the ~$75 to ~$99 shipped price range. Here's a cheap example for you, you'd Need to message the seller because they're not showing the tire size which needs to be a 135/80-16.
    WHEEL TPMS 16X4 SPARE FITS 03-17 COROLLA 1009922 | eBay
    Here's another, this one is a 135/80-16 on a 5x100 wheel; $75 shipped but "Make Offer" & get it for less.
    2011 TOYOTA PRIUS SPARE WHEEL TIRE T135 80 D16 DUNLOP OEM 10 11 12 13 14 15 | eBay
    Rob43
    #3 Rob43, Apr 15, 2018
  4. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    There’s no room on the Prime to store that spare tire unless you want to use that trunk space.
    PrimeDan likes this.
  5. Gagoo
    Gagoo Junior Member
    charlotte, nc
    2018 Prius Prime
    My model is the 2018 Prime Advanced:
    Based on a call to my local Toyota dealer for fit confirmation, I ordered the Toyota (17x4") "wheel Disc" 4261147631 then searched for a matching donut tire. Pickens for the tire were slim but I found the T125/70D-17 YOKOHAMA Y870C SL tire on Tire Rack. Brought the rim/tire to my local repair guy today for mounting and crossed my fingers for a fit. Just got it back, fit perfect he said. I am very pleased to now have a spare and very upset with Toyota for not at least offering a spare as an option. I might be an old schooler (driving a PMT, 2018 PRIME DONUT RIM & TIRE.JPG 2018 PRIME DONUT RIM & TIRE.JPG Poor Man's Tesla) but I am not driving a car without a spare tire, the goop repair option is laughable. Will likely keep it behind the passenger seat as suggested somewhere in these threads. Thanks to everyone out there who posted about this! 2018 PRIME DONUT RIM & TIRE.JPG .
    java007md and 1x1 like this.
  6. 1x1
    1x1 Member
    147
    45
  7. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
  8. Mendel Leisk
    41,226
  9. Salamander_King
    Salamander_King Senior Member
    11,014
    8,942
    New England
    I don't know how much space you can save by having a donut spare in PRIME's cargo. You will be limited 50 miles at 50 mph max with a donut on it. I bought a full size wheel and put one of good tire when I had to replace a pair of tire when one was not fixable. You can get aftermarket full size steel wheel for about $50~70. I don't carry it in the car all the time, but I have it stored in my garage in case I need it.
  10. Mendel Leisk
    41,226
    That's not onerous. A flat is a once in a blue moon event, and the temp spare's design purpose is just to get you out of harm's way, to some place where you can repair/replace the regular tire. It's a pretty good trade-off.
    i appreciate the values of a full-size spare too, say if you're on a road trip, but a temp spare is pretty good.
  11. Salamander_King
    11,014
    8,942
    New England
    Yeah, I totally understand usefulness of a compact spare tire for most cars if there is a space saver location you can store it in the car all the time. The problem is that Prime has no such space. Whither you have a donut spare or full size spare, you are going to have to sacrifice already limited cargo space and come up with some inventful idea to securely store it. The size difference between full size and donut for this case is minimal, but having a full size tire is much more useful IMO.
  12. DonJ
    DonJ Junior Member
    Fremont, CA
    2019 Prius Prime
    Thank you, Gagoo. Now I received my wheel disc and tire today. Did yours come with a valve stem? Or did your repair guy insert one for you?
  13. Mendel Leisk
    41,226
    Tire installers typically supply the valve.
  14. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    To all future readers of this thread:
    Try NOT to buy into a T125/70-17 spare tire size because their overall diameter is small at 23.9" inches. Remember that your Prime OE tire is 25.0" inches diameter and you want a spare tire that's close to this overall diameter. A 135/80-16 spare which has a 24.8" inch overall diameter would be a much better choice.
    Rob43
    #14 Rob43, Mar 13, 2019
    SeattleBebop1 likes this.
  15. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    You might check with your local Jeep dealer:
    The gas can is optional... for those with extreme range anxiety.
  16. Salamander_King
    11,014
    8,942
    New England
    I want it!. Does my local Jeep dealer install it on my PRIME for me? lol:ROFLMAO:
  17. DonJ
    DonJ Junior Member
    Fremont, CA
    2019 Prius Prime
    1. Yes, thank you. But the wheel appears to be correct. Here is a link that states the wheel is appropriate for Prius Prime, advanced and premium.
    2. According to Gagoo the T125/70-17 was a perfect fit. So I guess I need to work harder with the Toyota dealer to find an appropriate tire.
    Any comments?
  18. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    What if you just ordered and spare for a gen 4 trim three? Not the cheapest option, I'm sure, but perhaps the most expedient. I hope they didn't change the bolt pattern when they made the Prime. That would just be spiteful!
  19. Mendel Leisk
    41,226
    Yeah I think gen 3 Prius, Gen 4 Prius and Prime are all the same tires and rims. Get a 3 or 4 Gen Prius temp spare and you'll be good, say rim thru Toyota and tire you can look up on tire rack, either order there or local. Tire spec in Prius owners manual.
    jerrymildred likes this.
  20. Salamander_King
    11,014
    8,942
    New England
    I read in other thread, Gen3 spares works as well. If I had known that, I would have taken out the spare from my previous Gen3 Prius before trading it in. But since I didn't, and when I had early puncture on my Gen3 tire and I bought a pair instead of single tire. I had the extra good tire put on the steely as a full size spare for my Gen3. I never used it, but that's what I have for my PRIME now. In fact ordering a cheap steel wheel for a full size tire is cheaper than buying compact spare tire and a rim.
    #20 Salamander_King, Mar 14, 2019
