Flat Tire
Discussion in 'Gen 2 Prius Main Forum' started by huskers, Aug 25, 2006.
  1. huskers
    huskers Senior Member
    2,551
    2,490
    Nebraska
    I had my first flat tire in my Prius today. I was about 3 miles from home when a heard a beep and a flash on the dash. It was so fast I did not know what had lit up. The car did not feel different. Once home I went to the garage and noticed the back drivers side tire as flat as can be. I filled it up with that tire inflator stuff and got it to our local gas station. They fixed it with no problem (hole in tire but no nail). Could the beep have been the car trying to tell me that the tire pressure was not right?
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Yeah, i'd guess that was the tire pressure gauge going off, telling you it was low. Glad it was that easy!
  3. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(eagle33199 @ Aug 25 2006, 09:11 PM) [snapback]309694[/snapback]</div>
    There was no tire pressure monitoring system in the '05 model year.
  4. brandon
    brandon Member
    771
    Manhattan, KS
    Perhaps it was VSC.
  5. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    It was probably the VSC.
    I'd reccomend against using that tire inflator stuff, it corrodes the inside of the wheels and oftentimes can make repairable tires otherwise unrepairable.
    Thats what spares are for ;)
