Brand new battery voltage low 11.9 to 12.0, why?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chinna, Mar 19, 2019.
  1. chinna
    chinna Member
    162
    44
    Bellevue, WA USA
    2006 Prius with HID lights.
    I replaced original battery with Optima approx 8 years ago and now that battery was weak.
    Last week replaced with Bosch Premium Performance battery Group Size 51 AGM from pepboys. It was charged before putting in at 12.9v.
    Now a week later, I was checking battery voltage on the Screen, it seems low for charged battery.
    When I turn on Ignition (without brake) and check the voltage it is only showing 12.2v. No other loads.
    When I turn on Headlights(HIDs are only 35W each) voltage dropped to 11.9 and stabilized back to 12V.
    I thought for a brand new battery and fully charged it should have been higher than that. I was expecting close to 13 volts.
    Later I turned on car(with brake) and checked voltage and it is showing 14.2 v (it jumped to 14.3 but stabilized at 14.2) with headlights also.
    I am puzzled why battery is not charged fully and why it is not showing high voltage. There are no known loads/short . All lights are off when I was seeing 12.2v without headlights. Neither there was any incident where Lights were left on before this voltage measurement. Pretty much headlight were also off most of the driving last week.
    Any ideas, if this is normal, and I should be looking for some issue?
    Thanks
  2. RobertK
    RobertK Member
    128
    Norfolk, VA
    The car should be charging the battery at 13.8 volts if the 12 volt battery is fully charged. The 14.2 volts you are seeing indicates a low 12 volt battery. You should recharge the battery and see if the values change. If the battery can't hold around 12.9 volts you either have some drain on the battery or the battery is defective. Since the battery is brand new you might just have the store test it for you.
  3. chinna
    chinna Member
    162
    44
    Bellevue, WA USA
    I charged battery overnight, and it took lot of charge from my 6AMP charger before using. It was still charging when I checked in the early morning. Battery voltage was showing 12.9 after disconnecting the charger.
    Instead of battery voltage increasing as battery gets charged from car, it went down. I am pretty positive about not having any external discharge when car is off. But I can check/monitor as I have Clamp On multimeter if there is any drain after the car is turned off.
    I was more worried about if there is any chance that charging circuit is going bad.
  4. RobertK
    RobertK Member
    128
    Norfolk, VA
    Given that you are getting 14.2 volts while in Ready mode, I think your car's charging circuit is OK. I would charge it again with your battery charger until the charger indicates that the battery is fully charged. This will probably be best if done overnight.
    How old is your new battery? If it is more than six months old it might be the cause of your problem.
    Out of curiosity, how did you install the Group 51 battery in the Prius, given the different terminals on that battery? Did you replace the terminals on the cables? I'm wondering if you might have a bad connection that is keeping the battery from fully charging.
  5. Mendel Leisk
    41,912
    Let the car sit overnight, with the hood ajar. Check the voltage first thing in the morning, at the underhood jumpstart point, with a digital multimeter. All the readings using the dash display are kinda meaningless.
    scona likes this.
  6. chinna
    chinna Member
    162
    44
    Bellevue, WA USA
    This is same size as Standard AGM battery with Smart Key. Terminals are same size and has usual vent elbow to connect.
    Here is the battery
    Bosch Premium Performance Battery Group, Size 51 | 647478 | Pep Boys
  7. Mendel Leisk
    41,912
    Pep Boys should an electronic load tester on hand. They really should have tested it before sale but anyway:
    drive down there, have them test it, and if it's a dud take advantage of the warranty?
  8. johnHRP
    johnHRP Active Member
    645
    189
    KA, DE
    Excel
    I am afraid it is an old tread but we should correct the information here. There is nothing wrong with that battery. It is practically new with 12V under IGN ON and Headlight On.
    Typical normal working battery with Halogen Headlights ON 18 Amps, is 11.5V or more.
    Voltage reading alone gives incomplete picture about the capacity of the battery. Running All Accessories: headlight, blower, defroster etc. give better picture if the aux battery is still good. If it is below 10.5V, get ready with Ultracapacitor jump starter. When it is below 10V, you will start seeing triangle.
  9. bisco
    52,395
    still, a new fully charged agm should measure close to 13 volts with everything off and no surface charge.
  10. johnHRP
    645
    189
    KA, DE
    Excel
    I doubt you ever have 13V once it is connected to the car. New battery often only read 12.9 V, from the display in ACC, you may get 12.8. Light load is not a good parameter. Turn to IGN ON and headlights On, it should be 11.5V or higher in a new fully charge battery
  11. bisco
    52,395
    agreed, that's why i said 'close to 13 volts
