Small humming at 8mph to 12mph
Discussion in 'Gen 2 Prius Technical Discussion' started by Tweldon, Aug 26, 2006.
  1. Tweldon
    Tweldon New Member
    My new prius seems to have a small humming sound in the motor area when the ICE is kicked in at 8 - 12mph :( . At 13mph it stops. It almost sounds like the pump(?) you sometimes here when you turn off your car. Usually it is whenthe car is warned up, sometimes the first block, it doesn't happen.
    This also occasionally occurs at 28 - 25mph when slowing, though not as consistent. Has anyone experienced this? Is it normal?
    Should I have service check it out?
    Any imput would be appreciated.
    Cheers,
    Tweldon
  2. pagoda113
    pagoda113 New Member
    17
    Mine does the same. Only been driving 500 miles. Would love to know if its normal and/or why?
  3. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    there are lots of new hums and whines you'll hear that you'll get used to as you drive.
    first, there's the brake accumulator pump which essentially pressurizes your brake system. you can hear this by stepping on the brake pedal for a long time (like at a long stoplight) it'll kick in to keep pressure.
    then there's the coolant pump, which you'll hear when you start up and after you shut down, and occasionally as you drive.
    there's also the inverter whine, which you'll hear very clearly while driving in electric and while braking.
    it's probably something normal that you have yet to get used to, if something was wrong you'd hear it all the time (as in accumulator pump running all the time to keep brake pressure) or there'd be a check engine light or something to warn you on the dash.
  4. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Yep lots of new noises, that is why you need to have good tunes going all the time!
  5. Tweldon
    Tweldon New Member
    Yes, I can understand these various noises, but a very consistent humm/buzz between a 8 – 12mph is something I’m curious about. Do you have this in your Prius? What is it?
    During the test drive it was non-existent, or I would have asked about it. Only arose after a few 100 miles. A friend who has a ’06 does not have this, though I have not driven his car.
    Does any one else have this or know what it may be?
    Cheers,
    Tweldon
  6. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Galaxee's tip about the inverter might be what you're talking about. I've noticed the accumulator pump coming on, and the coolant pump when I get out... I haven't noticed a buzz at low speeds, but I bet now that you mentioned it I will ;)
  7. Tweldon
    Tweldon New Member
    <div class='quotetop'>QUOTE(Ichabod @ Aug 26 2006, 10:33 PM) [snapback]309993[/snapback]</div>
    Give it a try tomorrow and let post what you find. It starts at ~ 8mph and ends right at 13mph on the nose.
    Cheers,
    Tweldon
