Can the EGR Circuit be monitored?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tonynap, Mar 22, 2019.
  1. tonynap
    tonynap Member
    43
    37
    NY
    Hey everyone. I am using Torque Pro and OBDLink LX to monitor the goings on inside the Prius.
    For example, I created two layouts that monitor the hybrid battery voltage, resistance, charge, temps etc. I'm hoping this will help me to catch any HV issues early.
    I'd like to create a layout to monitor the EGR Circuit as well. I'm seeking guidance on what to include.
    Thanks in advance.
    48,946
    not that i recall reading
  3. Leadfoot J. McCoalroller
    6,803
    6,454
    Pennsylvania
    2018 Prius c
    Some cars have EGR flow sensors but I don't think Toyota does it. There may still be a way through indirect measurements. You could almost certainly get something by monitoring the knock counter. One problem with that is that while insufficient EGR flow will increase the knock count, it isn't the only condition that can cause this effect.
    Robert Holt likes this.
  4. rjparker
    7,570
    4,438
    Toyota does monitor it since they can set the P0401 for Insufficient EGR Flow. With electrically operated egr valves, the engine ecu can test the EGR circuit by forcing it open with the engine idling. This should cause the engine to idle poorly or run rough
    If ecu cycling of the valve has no effect on engine idle, the EGR system is plugged up and or the EGR valve has failed.
    Mendel Leisk, mjoo, Prieth and 5 others like this.
  5. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    That's the best scenario for the driver.
    I've heard from a few sources here that the EGR system can get completely sealed up and not generate a P0401. Maybe the MAP sensor ranges that trigger the P0401 are too lax? How does the pool of oil submerging the MAP sensor affect sensor readings? There's also the buildup of carbon in the intake manifold that should change the distribution of vacuum inside the IM to cause higher pressures before the restriction (at the MAP sensor).
  6. Mendel Leisk
    38,217
    Depending on the definition of "monitoring": periodically inspecting just the pipe might do.
    @NutzAboutBolts has a video for that, goes through the steps to remove air intake as well.
    Merkey likes this.
  7. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    It can be monitored. If the head gasket blows, the EGR is clogged. If the head gasket is operational, the EGR is probably still clogged.
    Takeaways, Clean your EGR.
  8. Merkey
    Merkey Active Member
    252
    228
    Birmingham, Michigan
    Periodically inspecting the pipe is what I plan on doing.
  9. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    Do the main passages in the manifold actually clog to that degree? I understand that the EGR passages can.
  10. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    It can collect in the head after the intake manifold. At 70k mine had stalagmites. IM, EGR cleanse and a few rounds of Techron cleaned it up.
    Pixel XL ?
    Raytheeagle likes this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    Yours was also the subject of more experiments than the rest:cool:.
    Particularly from a “run it out of gas” perspective ;).
    But the circuit is cleansed now and in good sorts (y).
    mjoo likes this.
  12. wheezyglider
    wheezyglider Active Member
    247
    177
    SF Bay Area
    After seeing that gnarly fuel pump filter photo Raytheeagle posted not too long ago, I'll never let my tank get low again. (Just hoping not to pump a bunch of sediment at once.)
    Regarding the monitoring of the EGR circuit via OBD, it would be interesting to see if the max commanded EGR changes before/after cleaning. As in, does the computer know to open the valve more when clogged in order to get what it needs? On my post-cooler-cleaning Prii, the computer never commands more than 60-70% from the EGR valve.
    There was a difference before/after on the "EGR flow insufficiency" monitor numbers, but there's currently no easy way to ask for that without using Techstream. (It's likely technically possible with an OBD2 dongle, but might not be as simple as discovering a custom PID for use with Torque. If I were selling Dr. Prius app, I'd definitely look into it. At the very least snoop the USB communication via usbcap while using Techstream to read the value. But I digress... )
    The EGR flow insufficiency monitor seems to be a test that runs (occasionally? once after warmup?) in the background, with the results stored by an ECU. As opposed to a sensor that updates in real time.
    To add to the list of things we don't quite know, it's not clear AFAIK if the EGR valve has a position sensor. It has a bunch of wires like a throttle (which often uses 2 wires for command, 3 for sensing position). The EGR valve has 6 wires ,so it might have a position sensor. But I don't think the custom PID for EGR Step ever mismatches EGR Commanded (--by more than sampling delay would explain).
    TLDR: we don't know how to monitor the EGR circuit, but the pieces might be there.
  13. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    I figured the fuel filter would get some attention ;).
    And remember I never let it get below one bar or wait for the flashi last PIP to let me know to refuel:cool:.
    Glad it helped (y).
  14. ChapmanF
    15,075
    I believe it is a stepper motor.
  15. tonynap
    tonynap Member
    43
    37
    NY
    It is a stepper motor, and the step position has a PID so you can monitor it in Torque.
    The screen I ended up building is basically monitoring for the misfiring and high temperatures that seems to precede failures.
    The next thing I need to determine is the significance of a misfire count of 1. It's never 2, and it's never the same cylinder.
