Unswitched 12v Power Source behind Accessory Panel or Kick Panel?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by MARK A SLOO sloo, Mar 24, 2019.
  1. MARK A SLOO sloo
    MARK A SLOO sloo Junior Member
    Minneapolis
    Has anyone found a source to tap for unswitched (i.e. always on) 12v power in the area to the left and below the steering wheel (10amp fused preferred)? I've searched extensively on Priuschat and there are links in older threads that may have been promising, but the links are no longer valid. Any help much appreciated!
    Prieth likes this.
  2. MARK A SLOO sloo
    Minneapolis
    I think I found a source. The attached diagram is the ODBII port showing Pin 16 red wire as unswitched 7.5a power.
    • 001.pdf
      File size:
      17.1 KB
  3. Mendel Leisk
    38,247
    OBD port for sure has a pin that's always powered. Memory saver cables employ it.
    I checked mine; these connections have continuity:
    #3 Mendel Leisk, Mar 25, 2019
  4. jtchinoy
    jtchinoy New Member
    Hayward, California
    Pretty sure this is the information you're looking for. Got this from the DIY JDM Signal Mirror thread.
    Prieth likes this.
  5. MARK A SLOO sloo
    Minneapolis
    Thanks! Your second attachment 132314 looks like the UL2 connector in my diagrams. The 3rd attachment doesn't open for me.
    Does anyone know where the UL2 connector is located?
