Featured Reasons behind the slowness of EVs adoption in US
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by KrPtNk, Mar 11, 2019.
  1. bisco
    51,840
    they don't know it, so it doesn't matter. range, they know. cost, they know. they can make informed decisions based on those and other factors, and many are.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The range and cost problems are caused by the lack of energy density. Think about it - if energy density were four times higher and cost were the same per unit of mass, then you could have four times the range for the same cost or the same range for 1/4th the battery cost.
  3. bisco
    51,840
    semantics, i'm fine with it. but let's circle back: jmo, it doesn't suck.
  4. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    The "power plant" in your Mazda is a heater, which provides a bit of motive power.
    When you are throwing away 3/4 of the energy of the fuel as useless heat does it really matter that the fuel starts out with more energy density?
  5. Lee Jay
    5,850
    4,036
    Well, the engine/fuel tank in my 1988 Mazda was four times better and lasted 31 years before I sold it, still running like brand-new. 30 years of development and state-of-the-art technology can't come close to that, and that sucks.
  6. Lee Jay
    5,850
    4,036
    It does because it's *production* of energy is still four times more than the best batteries (over 800Wh/kg), despite losing all that energy to heat.
  7. bisco
    51,840
    i'll let you have the last word, it seems important to you :)
    hill and markabele like this.
  8. Lee Jay
    5,850
    4,036
    Let me put it this way.
    If batteries didn't "suck", an extended range Model 3 would cost around $7,000 less and a base would cost around $5,000 less. Think that would make a difference?
    The Base would be $29,500 instead of $35,000 and the ER would be $37,500 instead of $44,500.
    I'd call that a major difference.
  9. hill
    8,793
    perhaps one needs to consider efficiency. The Wright brothers plane was far from efficient, despite the density of the fuel. PV stored electrons are non-carcinogenic, nor are wars fought over thwm. But whatever works for folks.
    #229 hill, Mar 26, 2019
    Zythryn likes this.
  10. Lee Jay
    5,850
    4,036
    Yes, it's amazing that a 15-20% efficient solution can still dominate on total energy output despite the huge losses.
    That's why it's going to be really, really hard to get to the point of electric airliners. The power of jets and the total energy of jet fuel are both absolutely enormous. The engines on a plane like a 777 can be thought of as 50MW each, in cruise, or thereabouts. Now sustain that for 16 hours and you've got 1,600,000 kWh of storage in those tanks. Batteries that can store that would weigh 10 times what the entire plane weighs.
  11. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Is it J1772 or CHAdeMO?
    Mike
  12. ETC(SS)
    7,134
    Yeah....and IIRC airliners are still < 50% "efficient." depending on what you call "efficient."
    Perhaps someday after the 'lectric car conquers tractor-trailers and solar scales up.....
  13. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Yeah, that is probably true. My point was that the current L2 chargers being installed (except at home) barely count as long term infrastructure when you look a decade ahead. Only high speed chargers on the interstate really count. PHEVs do not ever, IMO, push that long term infrastructure...they kick that can down the road.
    Mike
    Trollbait likes this.
  14. 3PriusMike
    3,100
    2,419
    Silicon Valley
    In ~3 months my PIP will be 7 years old. I have often done a second or third charge per day and really wanted a faster charger. But in reality the number of EV miles I've given up because I couldn't charge fast enough is a few hundred. And, of course the PIP doesn't even charge that fast.
    With the Tesla M3 I've been able to ignore the self imposed PIP EV range anxiety.
    My battery has only gone under 100 miles remaining a few times and under 50 once.
    Mike
  15. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    What does that have to do with the mainstream market so many years later? All an early-adopter can really do effectively is demonstrate the technology, proving it delivers well from an engineering perspective. Your heighted awareness alone cancels out any chance of you sharing a similar ownership experience with typical consumers.
    You're looking at it backward. Again, know your audience. There are electricity providers all around the country gearing up to do the push. As a PHEV owner, it's just a matter of taking them up on the upgrade opportunity. They want you to use more electricity, to get on their time-of-use programs, to want your next vehicle purchase to rely on electricity even more.
    #235 john1701a, Mar 26, 2019
  16. hill
    8,793
    Another article contradicting slow growth of plug-ins
    Tesla will overrun traditional car companies because they still aren’t moving fast enough - MarketWatch
    So - apparently the folks at MarketWatch think the op is full of it
    Zythryn likes this.
  17. Lee Jay
    5,850
    4,036
    CHAdeMO or ICS.
  18. bisco
    51,840
    pure guesswork and opinion. ev's will grow slowly enough that anyone can play catch up if they so choose.
    in the meantime, they'll do everything they can to stop tesla from killing the golden goose.
    o/p was pretty much spot on.
  19. bwilson4web
    16,187
    Parked our Standard Range Plus Model 3 on the driveway about 4:30 PM (CST).
  20. bisco
    51,840
    pics or it didn't happen :cool:
    markabele likes this.
