Confused
Discussion in 'Gen 2 Prius Technical Discussion' started by TsukiNaito, Mar 27, 2019.
  1. TsukiNaito
    TsukiNaito New Member
    Oregon
    I
    So, my 2005 just hit 294k miles, and its starting to really show its age. for the last few months the battery has been discharging extremely quickly and charging extremely slow.
    I had assumed maybe one of my battery cells was bad and i could just replace it, but to confirm i downloaded Torque Pro just to check the voltages of each block before i took the car apart.
    i had expected to see one block significantly lower than the rest(or at least a little lower). but after letting it run during my half hour drive to work, it reported fairly even numbers across the board.
    Does this mean i just need an entirely new battery instead of just replacing individual cells, or should i tear the whole thing apart and actually check the voltages of each cell individually, or could this be indicative of another issue entirely?
    52,188
    more than likely, or maybe there's a lot of corrosion. tech stream might give you a better diagnosis, but if you're keeping the car, why not spend the $1,600. for a brand new battery?
  3. TsukiNaito
    Oregon
    I
    mostly because if the battery is still good, i'd rather wait on spending the $1,600. i dont want to end up with a new battery not being the fix until i know for sure. corrosion could definitely be a possibility with the age.
    should i just take it apart at this point and see what im dealing with.
    i should also note, there is no check engine light, and no red triangle at this point. and Torque did not find any pending codes
  4. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    I had majaor amounts of corrosion on my copper bars- even the dorman reman battery w zinc plated bars has major corrosion on a few key areas and studs for the battery terminals/nuts.... and its under two years old.
    I blame a big part on climate.....
    I used some oxidation grease to see if it would keep away the major amounts on key areas.....and all lugs of course.
    I am also suspect if upgrading to gen3 cells would be worth it...…
  5. TsukiNaito
    Oregon
    I
    Would this have such a drastic affect on charge rate? and can i actually put gen3 cells in a gen2?
    #5 TsukiNaito, Mar 27, 2019
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Here is your problem. You're checking after they've been charged for 30 minutes. If you want to look for a difference in block voltages, it would be best to do it after the battery has sat unused, overnight, etc. That will give a bad cell/module plenty of time to self discharge/return to it's equilibrium state .
    Raytheeagle likes this.
  7. TsukiNaito
    Oregon
    I
    it was about the same when i checked it first thing, but i will do it again tomorrow morning to be sure
  8. dolj
    dolj Senior Member
    8,490
    4,308
    Wellington, New Zealand
    Possibly, but you may also be able to benefit from a full reconditioning cycle using the HA Prolong Charger/Discharger system.
    If you were able to borrow one for a week, plus buy your own harness cable, it could be worth a try.
    #8 dolj, Mar 27, 2019
