No smart key function 2005 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ishx93, Mar 27, 2019.
  1. dolj
    dolj Senior Member
    7,652
    3,864
    Wellington, New Zealand
    For $60 it won't be new and so you won't be able to use the chicken dance or techstream (without a seed reset). Secondly, without a working key fob, you won't be able to program a second key.
    Wrong. The SKS and non-SKS use different transmitters for the remote lock/unlock and they are not interchangeable.
    I continue to read with amusement that you both have identified that the CM is flakey, and for some reason you both are refusing to fix the obvious.
    Now, I can't say for certain whether the CM is the root of all your problems, but it is a keystone to some of them. Fix the obvious (and relatively) easy problems first and then see where you end up.
    It isn't rocket science, chaps! :whistle:
    Skibob likes this.
  2. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    You think a flaky Combo Meter is the root of the issues?
    I am unsure it's the MAIN reason- now can I fix it -sure
    I am new to all of this - most of my knowledge is from trial and error-
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,226
    5,910
    Columbia, SC
    It's hard to argue with the logic of dolj:
    "fix the obvious first".....
    It's something that you know 100% has to be fixed. If that fix may solve the other problems, why not do it first, rather than potentially wasting a lot of time and effort and then having to do it anyway?
    Skibob likes this.
  4. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    Very true
    I am looking to do this when we have a dry day
    Been raining every free chance I get
  5. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Sometimes it’s just better to walk away
  6. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    Dolj-
    I'm not against repairing items as I Can-
    Some items are more of a necessity- I will do the Combo board ASAP to see if it repairs my issue.
    I have a tech stream PC/ and Cable coming end of week.
    Thanks for your input-
