I fixed my wonky cruise control
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tynyyn, Mar 30, 2019.
  1. Tynyyn
    Tynyyn Member
    109
    29
    Bella Vista Arkansas
    Whenever I press the cruise control button on the stalk, I notice the "cruise" light on the dashboard just blinks. Sometimes when I depress the brake pedal I notice the "cruise" light will stay lit for a while. Made me wonder if the brake light switch was bad. So I trundled down to my local O'reillys and purchased a new brake light switch for $30 and installed it. Now, the amount of time, effort, and swearing was outrageous for the switch installation due to its location and inaccessibility, but after 45 minutes I got the switch installed. Then I went to work and pressed the "cruise" button and it worked perfectly. The light never blinked, but instead was steadily on.
    I had purchased a clock spring but it hasn't arrived from China, yet. The clock spring replacement was going to be my main repair for my cruise control problem, but I am glad that the brake pedal switch was the true culprit.
    Hope this helps folks who might be figuring out how to fix this problem.
    bisco and SFO like this.
    52,419
    beware chinese clock springs
  3. terramir
    terramir Member
    319
    51
    Los Angeles
    Yeah,
    I Second That!!!!!!
    Your better off very carefully uninstalling one from the junkyard. Chances are you will get a good one because people that are not handy tend to get it fixed. The contacts to the airbag are tricky you might have to solder to replace them . But as long as you pull up the locks with a jewelry screw driver you have an 80% chance of getting it out intact.
    This is how I fixed my cruise control.
    And buttons just check the car has the same buttons on the steering wheel you should be golden.
    terramir
