Prime in the wild.
Discussion in 'Prime Main Forum (2017-2022)' started by bisco, Dec 7, 2016.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,156
    Tampa, FL
    I've seen a few around here, but the Southeast distributors are as stupid as the Gulf States. They are far more rare here than Teslas. I see those every day. I have not seen a Prime since I got my own two weeks ago. Really want to honk and wave. :ROFLMAO::ROFLMAO::ROFLMAO:
    Hayman66 and HPrimeAdvanced like this.
  2. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    You must have the worst luck when it comes to cars.
    2015 Prius 4- Totaled by Wylie Hail Storm
    2016 Prius 4- Totaled by Hurrican Harvey
    2017 Prius Prime Advanced - Totaled by Tornado TBD
    I saw that Jason Alexander drives a Prime:
    Hayman66 likes this.
  3. jerrymildred
    11,517
    14,156
    Tampa, FL
    I finally saw my first Prime since getting my own over three weeks ago. Based on the 11" display and lack of fog lights, I'd say it's a Premium. It was white and was one row over in the grocery store parking lot. The guy was just putting his stuff in the hatch as we came out of the store, so I went over and introduced myself. He was elderly and had a very British accent. Nice guy. He had bought his w/o a test drive by ordering it from our local dealer and really loves it. Said he's put 6,000 miles on it so far and only bought gas three times. I mentioned that I thought I saw him a while ago pulling out from the pharmacy across the street. He said he'd never been in that pharmacy, so that confirmed my theory that there are two white Primes in my area. AFAIK, there are no others.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    I just made our appointment on the 14th for our test drive and purchase:).
    Blue magnetism it is in the plus trim(y).
  5. jerrymildred
    11,517
    14,156
    Tampa, FL
    Woo hoo!!!! This thing is amazing. I don't know how yours will do in your driving environment. But the temperature was in the upper 60s this morning and after driving 9.5 miles to work in light traffic at 45-54 mph, I still have 28.9 estimated EV miles left. Eco diary shows 6.7 m/kWh after that drive. And it's just plain nice to drive. :D
    If I had the resources, I'd buy my wife one of the blue ones even though she swears she doesn't want to replace her '07. She loves that color. And we need to hang on to one five-seater for the rare times we have our grandsons and my mother-in-law visiting at the same time.
  6. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    My commute is 38 miles one way, so I’ll be a mixed bag:(.
    But I’ll charge at work and at home (have a solar array at the house to aid in this equation) so that should help out:).
    I thought 50 mpg was good for my commute in our Gen3;).
    Can’t wait for even better results(y).
  7. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    Before I retired, I had a similar commute (35 miles). I was only able to charge at home and averaged 108 mpg for the 6 months that I had to commute. Charging at work and at home will make you very happy mpg-wise. ;)
  8. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Excellent :).
    My commute is mostly flat, but 3/4 of the way into the commute I have to crest Willow Pass on Highway 4:(.
    This is the spot that usually gets the Gen3 ;).
    But going home in a full charge I should be in really good shape to handle it(y).
  9. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    I guess another question for you @Prius from Dad , did you drain the battery in EV mode, or allow the Prius to decide?
    Not sure if I want to drain the battery, then have the engine wake up to 70 mph conditions :oops:.
  10. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    In your weather, PRIME can get up to 65 mpg on gas only HV mode easily. I just changed my snow tires yesterday on my PRIME, and my first commute this morning on OEM Dunlop tire was up to 63 mpg. I did not charge last night for comparison of HV only mpg between tire change. Temp was still on the cool side of 33F, but big jump from ~50 mpg I have been getting with snow tires.
  11. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    I tried it a few different ways and there wasn't much difference mpg-wise. I finally stayed with draining the battery. I don't think waking up the ICE at cruising speeds is harmful. Your rpm's are lowish.
  12. jerrymildred
    11,517
    14,156
    Tampa, FL
    I switched to EV at 70 mph one time so far. MPG bar was showing about 80 mpg for quite a while as the engine warmed up and borrowed from the battery.
  13. Blauer Glimmer
    Blauer Glimmer Active Member
    448
    169
    NY (Southern Tier)
    Snows come off next week & temps starting to be more consistently above freezing (Spring in Western NY is a very mixed bag). Can't wait to see those mpgs come up again! I have a 700-mile road trip planned for the following weekend with no charging availability.
  14. Salamander_King
    11,019
    8,954
    New England
    Just a perfect timing for the efficiency boost with the gas price creeping upward everywhere. You should be able to complete your 700 miles trip with a single fuel-up in a middle no problem.
    HPrimeAdvanced likes this.
  15. Blauer Glimmer
    448
    169
    NY (Southern Tier)
    Made the same trip last August - low 60's mpg on the way down (generally hi-lo elevation); mid-50's mpg on the way back up with a single fill-up. Not sure it will be as good, since temps are cooler right now, but it should be in that ballpark. Still quite an improvement over my '09 Prius!
  16. Prodigyplace
    12,617
    11,803
    Central Virginia
    Now @jerrymildred needs to step up his work on @bisco and @Mendel Leisk ;)
  17. bisco
    52,170
    prime is not currently on my list. hoping the next iteration has a full hatch, if i haven't gone full ev before then.
  18. Mendel Leisk
    41,735
    No spare, don't care. :p
    Seriously, we'll likely sit tight with our low miles (80K kms) 2010 Canadian Touring for quite some time yet. Our usage is really low now too: "filling up" maybe once a month, and then only 20~25 liters (tank is 45 liters).
    In Canada, as of 2019 model year, ONLY the base Prius has a spare.
    Here's a snip from the 2010 Canadian brochure:
    (Doesn't say in the above, but the hatch is also touch to lock/unlock.)
    #298 Mendel Leisk, Apr 1, 2019
    Prodigyplace likes this.
  19. Prodigyplace
    12,617
    11,803
    Central Virginia
    Perhaps Bob will sell you his i3 REx :D
    HPrimeAdvanced and jerrymildred like this.
  20. bisco
    52,170
    yeah, no. too small. i see 12 kona ev's in eastern ma. may take a test drive this summer
