Connect OEM camera with IPA to Android Headunit
Discussion in 'Gen 3 Prius Audio and Electronics' started by RVBPRIUS, Jun 28, 2017.
  1. RVBPRIUS
    RVBPRIUS New Member
    Holland
    I own a Prius 3rd Gen from 2009 with Intelligent Parking Assist. I recently purchased this Android Head Unit (Octa-core 32GB ROM / 2GB RAM with Android 6.0). I now want to connect the OEM camera to this unit.
    I understand that my OEM rear camera does not connect to the radio. It connects to the self parking ECU behind the glove box. When I shift into reverse, the head unit receives the reverse signal (+12V pink wire L42 plug) and converts it into canbus then goes to the self parking ECU and triggers the reverse camera. Camera power is also from the self parking ECU not the head unit. The reverse image (analog NTSC signal) goes from the rear camera to the self parking ECU. The ECU converts the analog NTSC signal into digital signal and routes to the head unit with self parking overlay through the GVIF cable (L105 plug).
    My head unit has a female RCA cable to provide its video signal, and also a reverse wire in. See the diagram below.
    How can I connect my OEM camera? Do I need some sort of GVIF to RCA converter? I thought I could splice some wires and use a 12v to 6V converter to get my video signal to my Aftermarket head unit, I just figured out my Prius has IPA so this changes the situation.
    This is how my current OEM nav systems looks like.
    Any suggestions?
    edit: turns out I can post links until I post 4 times (strange rule). This Is why I will reply to my own post 4 times so I can post links. Please ignore those posts.
    #1 RVBPRIUS, Jun 28, 2017
  2. RVBPRIUS
    RVBPRIUS New Member
    Holland
  3. RVBPRIUS
    RVBPRIUS New Member
    Holland
  4. RVBPRIUS
    RVBPRIUS New Member
    Holland
  5. RVBPRIUS
    RVBPRIUS New Member
    Holland
  6. RVBPRIUS
    RVBPRIUS New Member
    Holland
    Today I removed the glove box and took a picture. Someone who can point out the self parking ECU?
  7. RVBPRIUS
    RVBPRIUS New Member
    Holland
  8. RVBPRIUS
    RVBPRIUS New Member
    Holland
    Did some trial and error and found the self parking ECU. Also found the video signal cable. If I disconnect this cable there is no more video image displayed. See picture below.
  9. RVBPRIUS
    RVBPRIUS New Member
    Holland
    Anyone who knows what kind of plug that video cable is? Can't find a RCA adapter on aliexpress/google.
    edit: found out that is the GVIF cable to OEM head unit. So the RCA video feed will come from one of the wires in the plugs above the GVIF cable.
    #9 RVBPRIUS, Jul 1, 2017
  10. cinamo
    cinamo New Member
    Netherlands
    Did you ever find out how to wire it? Am struggling with the same thing, would be very happy to hear that you figured it out
  11. tegenwind
    tegenwind Junior Member
    Netherlands
    I am also curious to know how this would work. This is one of the things that keeps me from buying the Android head unit.
  12. gptoyz
    gptoyz Junior Member
    85
    17
    los altos
    Bump - did anyone ever find a solution?
  13. mihaitaus
    mihaitaus Junior Member
    Romania
    2013 Prius Plug-in
    So I have the same problem with the 4 post rule so please ignore them.
  14. mihaitaus
    Romania
    2013 Prius Plug-in
    I also have the factory JBL unit with the amplifier under the passenger seat.
  15. mihaitaus
    Romania
    2013 Prius Plug-in
    And the factory camera. I just ordered from Ali... an Android unit that the seller said it will work withy amplifier and my camera. When it will arrive I hope I will remember to keep you posted.
  16. FrancisT
    FrancisT Junior Member
    Brisbane, Australia
    i-Tech
    Late to the party! Did anyone find a solution?
  17. Syzygianinfern0
    Syzygianinfern0 New Member
    Austin, TX
    2014 Prius v wagon
    Bumping once more :cry:
