  1. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Whoaa, is this real life?
  2. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
  3. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    It's not just fantasy:whistle::whistle::whistle:
    James Powers likes this.
  4. Nopho4u
    1,007
    2,061
    Socal son
  5. James Powers
    396
    555
    Bay Area
  6. Nopho4u
    1,007
    2,061
    Socal son
    Ideally I would like to get Brembo for my own car but unfortunately this is only a 4 pot calipers. Looking for a 6 pot 365mm rotor Possibly from r1
  7. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    So sexy it hurts!
    sfv41901 and Daigi_ like this.
  8. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
    Haven’t done nothing new. Just 82k oil change :confused:
  9. RacingSystems
    RacingSystems Junior Member
    24
    76
    Germany
    #17229 RacingSystems, Apr 4, 2019
  10. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
  11. orenji
    orenji Senior Member
    5,887
    3,488
    Exactly what I want to do! Was going to go with a JDM tail light, but why spend your money when one LED bulb and switch is all you really need.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    @The Critic stopped by today and we got a couple of things done :):
    • Oil change and catch can empty (collected 4 ounces since the last drain 10k miles ago)
    • Inverter coolant drain and fill
    • Inverter pump replacement (preventative maintenance)
    • Fuel pump replacement (preventative maintenance)
    Some pics:
    E9573AE8-2D8D-4CB0-999E-5450BDA53B55.jpeg 3F172570-D9C1-4366-8CFA-2AD82A5A8947.jpeg B30E4BF8-C705-4A1B-BCC6-FBAEED74BBB2.jpeg D7BE6233-774A-4D69-8BE8-ADCAE0FCD8A8.jpeg F3120A15-9B1A-4A99-AB4E-D3872FD698C3.jpeg 805A354B-9839-4059-BEB6-31DF92AD1878.jpeg
    Inverter water pump done with just shifting it;).
    Good to always share a garage with @The Critic for an afternoon (y).
  13. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Got a lot done, and going w/0w-40 eh? At that rate, youre gonna reach 400,000 mi on original engine. Chance to film any of it?
    James Powers and Raytheeagle like this.
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    No film and that mileage will be on someone else’s watch;).
    I’m Prime for an upgrade on the 14th(y).
    James Powers and m.wynn like this.
  15. orenji
    5,887
    3,488
    Doing the same tomorrow, Mobil 1 oil 0W-40 and first empty of my new Catch Can!
    Raytheeagle likes this.
  16. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I had to pull my catch can off as the dip stick wouldn’t seal:(.
    So I just replumbed it back as designed ;).
    I’m selling it anyway at the end of the month, so I’ll let the new owner decide if they want a catch can or not(y).
  17. orenji
    5,887
    3,488
    What do you mean the dip stick won’t seal? Pressure was pushing it out?
  18. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    The threads on the catch can dip stick won’t catch on the lid :cool:.
    The threads aren’t cross threaded either:(.
    Just something I noticed when putting everything back together. So I took it out to avoid a pressure differential issue;).
    Not ideal for our 200k mile Prius, but it’ll work(y).
  19. orenji
    5,887
    3,488
    Oh. I see. My catch can has no dip stick just the lid.
  20. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Not important if you mount the catch can high, but if you mount low, you need the dip stick;).
    Guess where mine was mounted:whistle:?
    But I left the tin can there and will let the new owner know what i did along with give them the old catch can for their review:).
    It’s garage purge time from the Gen3 supplies(y).
