2013 Prius 3 "Check Hybrid System Stop the vehicle at a Safe Place" message
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TMPH, Mar 19, 2019.
  1. TMPH
    TMPH New Member
    Hi everyone, I just joined today. My 2013 Prius was running flawless until last night at 170995 miles. While accelerating the message "Check Hybrid System Stop the vehicle at a Safe Place" came on with the check engine and a yellow triangle with exclamation point lights. The "Ready" light is still on and I was able to shut off and start the vehicle 5 times completing deliveries then drove 90 miles home. Ever since the error message I noticed the engine is running constantly unlike before It only cycled when charging or full power needed. Once got home I searched Google for cause of this error and quick fix. Someone suggested disconnecting the 12v battery 10+ minutes to clear the message which I did but when I reconnect and try to start this time the engine did not start and with more if not all the warning dash lights came on and the "Ready" light never on. More googling suggested the 12v battery is weak/old about to die is causing this problem. Has anyone experience this problem and we're able to fix it. Any lead would be helpful, thanks.
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Have your 12v battery tested. Most auto parts stores, or independent battery shops will check it for free.
    TMPH likes this.
  3. bisco
    52,662
    have the codes read.
    possible culprits? inverter pump, hv battery, hv battery cooling fan, etc.
    Mendel Leisk and TMPH like this.
  4. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    The battery is near the end of its life expectancy. If a few hours on a charger lets the car start, then that was your problem. Buy a battery.
  5. TMPH
    TMPH New Member
    Sounds like a plan I hope is the 12v battery. Thanks
  6. bisco
    52,662
    none of that sounds like the 12v tome, test it first
    mikey_t and Mendel Leisk like this.
  7. TMPH
    TMPH New Member
    After disconnected (10+ mins) and reconnected the battery it did not start at all with all the warning lights and the "Ready" never comes on. Took the OEM battery to NAPA and got tested and they said it's putting half the amperage (feeling hopeful the 12v battery is causing all of it). Went home installed new battery but sadly it's the same problem. Going to buy an obd 2 scanner...
  8. Mendel Leisk
    42,152
    Dealerships can read the codes and give a verdict for around $100. Sounds like hybrid battery failing.
    mikey_t likes this.
  9. TMPH
    TMPH New Member
    Brought a code reader it gave 1 code the dreaded P0A80 faulty hybrid battery. Any chance a faulty or cut wire/cable would cause this?
  10. TMPH
    TMPH New Member
    Removed Hybrid battery covers and measured DC voltage at each cell with reading at each cell at least 9.3v. It seems the hybrid system failure is not the hybrid battery at this moment next I will be testing the inverter/converter and finally the coolant inverter coolant pump.
  11. bisco
    52,662
    you have to load test the modules, it's complicated. the eco is not measuring them while at rest.
  12. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    I want to see someone make the final stage of wack o mole though.
    #12 Grit, Mar 23, 2019
  13. padroo
    padroo Senior Member
    2,763
    2,253
    Check the negative battery terminal on the 12 V battery where it connects with the body of the car. Some have found this to be the problem.
  14. TMPH
    TMPH New Member
    Just checked it looks new with no sign of corrosion or loosen.
  15. TMPH
    TMPH New Member
    Load tested with 65watt headlight bulb every module holding steady at 7.3volts
  16. bisco
    52,662
    no corrosion inside the case or on any wire connectors?
  17. TMPH
    TMPH New Member
    Very light white/light green build up around the terminals and bus plates. I just received a recall from Toyota for Hybrid software update and the severed end of it could cause inverter/converter to fail. It could be that causing all the dash lights on with the hybrid failure...
  18. bisco
    52,662
    let's hope so!
    mikey_t likes this.
  19. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    I hope so as well!
    #19 mikey_t, Apr 22, 2019
  20. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Not likely. The freeze frame data for the fault code should be able to tell you which block is weak.
    pbk5621 likes this.
