  1. orenji
    orenji Senior Member
    5,887
    3,488
    If I change my oil and empty the catch can every 5K, you say I need a dip stick still? I am mounted low.
    What you getting for a new ride?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    What I’m saying is that you should check it every so often and if the dip stick doesn’t work or you don’t have one, it’s hard to know the lay of the land;).
    My commute doesn’t build goo in the can that a different climate or warm up cycle would. Every situation is different and produces different results. Having the can in for 25k miles and only generating 8 ounces of material, I felt confident that I would be fine:).
    Now for a new owner with new driving style or commute and not knowing the result, I felt it better to leave it off.
    Getting a Blue Magnetism Prime Plus by the 14th(y)
  3. orenji
    5,887
    3,488
    A61F1A53-49E2-495B-A9EE-BC2DF944E7C7.jpeg Was at Hybridpit today and changed my oil with Mobil 1 Oil and emptied my oil catch can! It certainly works!
    #17243 orenji, Apr 6, 2019
  4. orenji
    5,887
    3,488
    013EE9D0-CCA1-4C19-A332-ECC6EFE722F3.jpeg Had some Cusco added at Hybridpit today!
  5. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    Lowered it some more
    Daigi_, HelloHybrid, w84me and 12 others like this.
  6. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    Last week I installed my spin on filter conversion kit from Hybrid Pit. Incredibly easy install, and now I don't have to worry about the stuck filter housing anymore! Thanks again Hybrid Pit!
    And today I went out to Honda Fest in Tacoma Washington and got some track time in. Got a lot of attention afterwords based on how fast I was able to be. Hybrid power!
  7. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    Hurry up and get all the braces, rigid collar, steering rack brace, roll center corrector etc. I wanna see how much that helps for u
    orenji and tommy Wang like this.
  8. TheChip
    388
    1,210
    Misissippi
    Give me some part numbers and I'll get them ordered :D What's a roll center corrector?
    I have two likely dying cells so I need to get that handled before the next track day. No error codes yet but I am noticing the battery goes from full to nearly dead after one zero to sixty pull, which isn't doing me any favors. I'd also like to figure out a good way to get cold air into the HV battery system. Right now I'm planning to get a Zero Cool portable AC unit and have it blowing directly on the air intake. The other option is trying to find something I can hang out a window, hah!
    #17248 TheChip, Apr 7, 2019
    orenji, granTORRESmo and RightOnTime like this.
  9. Nopho4u
    1,007
    2,061
    Socal son
  10. tommy Wang
    tommy Wang Member
    40
    industry, CA 91789
    2017 Prius v wagon
  11. Nopho4u
    1,007
    2,061
    Socal son
    This is the cheapest I seen these items. normally it's 400 for front and rear but this one is like 2 something. big difference
  12. tommy Wang
    tommy Wang Member
    40
    industry, CA 91789
    2017 Prius v wagon
    Damn it. Gen 3 gets front and back. prius v only gets the rear..this blows:cry::cry:
  13. marvingloria2011
    marvingloria2011 Active Member
    109
    162
    Winnipeg, Manitoba, Canada
    That stance looks awesome! Can't wait for the weather to warm up some more so I can put my 19's on and drop it again. The streets are still dirty with lots of sand here.
    Putu Ariawan and granTORRESmo like this.
  14. granTORRESmo
    237
    648
    Norcal
    Bro let me see your car. 19s is dope!
    marvingloria2011 likes this.
  15. Nopho4u
    1,007
    2,061
    Socal son
    What do you mean adjusted do you mean your regular Drive height
    James Powers likes this.
  16. granTORRESmo
    237
    648
    Norcal
    Yeah I’m static bro. That’s my drive height
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    orenji, James Powers and Burna J like this.
  18. Nopho4u
    1,007
    2,061
    Socal son
    Thought u now were air
    sfv41901 and granTORRESmo like this.
  19. marvingloria2011
    109
    162
    Here you go. Not a current photo, but I want to try and go lower in the back. Just have to grind an sharp point off by the screw that holds the rear bumper to the the quarter panel and I think I'm good to go.
  20. granTORRESmo
    237
    648
    Norcal
    Oh yeah I saw this on the aftermarket wheel tread, nice bro! Yeah those screws are completely gone on my Prius lol
