Hot Coolant light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Olscratch, Apr 11, 2019.
  1. Olscratch
    Olscratch Junior Member
    So at 189,000 miles my 2010 prius had a head gasket leak resulting in misfires. I used copious amounts of Bar's Leaks Head Gasket repair poured directly into the engine coolant reservoir. To my surprise it worked, I stopped losing oil and the misfires ceased.
    I have since drained the Coolant/Bar's Leaks mixture and put another 14,000 miles on the prius.
    However whenever I'm on a longer highway trip going up a steep hill north of 65mph, my Engine Coolant Temperature light comes on and blinks until I'm over the hill and let off the accelerator. It also occasionally burps up some coolant through the cap on the coolant reservoir. My thinking is the Bar's Leaks Head Gasket repair solution has gunked up something inside the engine that is causing this.
    I'm looking for any tips on what to replace to fix this problem. Do I need a new radiator? Water pump? Any help greatly appreciated.
  2. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    I guess a new radiator
    Olscratch likes this.
  3. ChapmanF
    18,179
    That leak goop probably gets everywhere ... front radiator, heater core, EGR cooler, exhaust heat exchanger....
    Olscratch and Mendel Leisk like this.
  4. Mendel Leisk
    41,438
    Just sell it for scrap?
    Leak stop products should maybe be outlawed?
    The Critic likes this.
  5. cnc97
    cnc97 Senior Member
    1,422
    1,535
    Evansville, IN
    I’d say the water pump is giving you the trouble.
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I say put the Bar’s back in per instructions. It’s leaking again.
  7. padroo
    padroo Senior Member
    2,763
    2,252
    I would start by pressure testing the cooling system.
  8. Olscratch
    Problem solved. A new radiator fixed the issue. Swapped it with a buddy and it took us about 3 hours. I've put a thousand miles on it since and it hasn't belched any coolant or flashed hot coolant light once.
  9. padroo
    2,763
    2,252
    Any time you have your cooling system open for repairs it is a good idea to check the coolant level
    To make sure it is full.
