should I buy this prius? help... 2007 with 80000miles on it
Discussion in 'Gen 2 Prius Main Forum' started by Joanne12345, Apr 11, 2019.
  1. Joanne12345
    Joanne12345 New Member
    MI
    1998 Prius
    should I buy this prius.
    2007 with 80000 miles on it.
    49,500
    welcome!
    not unless you're a mechanic or have boatloads of cash
    Raytheeagle likes this.
  3. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    The question lacks adequate information to answer.
    Raytheeagle, Mendel Leisk and Skibob like this.
  4. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Can you repair your own car? Can you afford 1600 for a new traction battery or 800 for a rebuilt brake modulator plus labor if you cant? Have either of these been replaced yet? You don’t even say how much the car is. My advice is you buy a non hybrid car.
  5. Mendel Leisk
    38,728
    Yes.
    I kept moving my mouse across the above sentence, hoping one of the words was a hyperlink.
    Skibob likes this.
  6. audiodave
    audiodave Active Member
    787
    268
    US
    Miles are good but do you have mechanical abilities or friends that can help? Very reliable cars but that battery if original is on borrowed time.
    How much?
  7. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    On average, the 2008 is the most reliable year according to Consumer Reports.
    You never buy an average car, you buy one specific car.
    80,000 seems way under used to me, I would worry about batteries. (Prius have 300,000 mile life as taxis, as taxis drive 24/7, they do not spend much time not charging the battery)
    MI may have road salt issues, but should not over heat the batteries.
    At 11 years, this should be a car you enjoy working on yourself, not a car that needs dealer mechanics for everything. (One exception, try not to do brake work yourself)
    MilkyWay likes this.
  8. Mendel Leisk
    38,728
    80K's not way under used. It depends on the upkeep too. Our 2010 garage queen has 80K kms (50K miles), so far continuing to behave like it just rolled off the dealership lot.
    Raytheeagle and bisco like this.
  9. bisco
    49,500
    it's underused, just admit it. that's the first step to a cure :p
  10. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Some would say over maintained:p.
    Patrick Wong and Mendel Leisk like this.
  11. MilkyWay
    MilkyWay Active Member
    819
    358
    MI
    What is price? Link to ad?
    Maybe between 5 and 6k if it is mint.
    Set aside / expect to spend........
    about $300.....maybe 5 years from now..
  12. a_gray_prius
    2,927
    782
    IL
    When was the brake modulator ever a trouble spot for the Prius?
  13. Skibob
    2,912
    1,496
    Northern California
    Sorry, I meant the brake actuator assembly. People call it by so many different names I get confused.
