Steel wheels -- good source??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Apr 13, 2019.
  1. cyberpriusII
    1,157
    1,839
    Hyampom
    Cheapo basic steel wheels. Any suggestions. Tire Rack and Discount Tire don't seem to list them (although I guess I should call both of them and doublecheck.)
    Local wrecking yard guys are serious pirates so I avoid them whenever possible....
    52,380
    eBay?
    cyberpriusII likes this.
  3. Patrick Wong
    18,210
    6,513
  4. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    I can't speak to "rural Oregon", but in any major city Craigslist is full of steel wheels that people took off their cars to install "rimz"
    Look for Corolla or 2G Scion xB wheels. Direct fit, ought to be cheap.
    #4 egg_salad, Apr 14, 2019
  5. cyberpriusII
    1,157
    1,839
    Hyampom
    Thanks all. Great starting points. I see dedicated winter tires in my future....
    Raytheeagle likes this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    You’re close to the 49th parallel, @Mendel Leisk should be selling his Corolla Steelies this year to make way for the PIP rims he has in the shrine:).
    I’m sure he’d cut you a deal(y).
  7. cyberpriusII
    1,157
    1,839
    Hyampom
    Hmm
    I don't think I'm allowed back to BC since the time some friends and I had high tea at the Empress Hotel a decade+ ago....:whistle::whistle::whistle:...it seemed like a good idea at the time
    But, actually snuck this question into the Prius forum when I am really asking as I am planning purchase of an Outback and am thinking ahead for next winter --I think an Ouback with snow tires will be the safest bet next winter and for some reason I have become much more safety-oriented as it relates to driving...
  8. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    @Stevewoods seems happy with his Subie:).
    Drive what makes the most sense to you and if it is an Outback, enjoy;).
    The Prime we just got I can tell will be enjoyed for many years to come(y).
  9. Mendel Leisk
    41,893
    Here's info on my snow tire rims. They were $70 (CDN) apiece back in fall of 2010, through a local dealership (in conjunction with a snow tire package), and the lug nuts were $31 for all 20:
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    steel rim lug nuts, part no: 90942-01007 (plain, open-ended, galvanized)
    I found with the exposed hub opening things were rusting badly, found a 2" (nominal size, ID is 2.375") black ABS end cap (Home Depot) covered it nicely. It's slightly loose fit, but I found cutting a rubber band from an old bicycle inner tube, pushing on the hub opening rim, then pushing the end cap on, it was a snug fit, and stayed on.
    Also, the open-ended lug nuts mean the wheel stud tips are exposed, start to rust-bloom. After install putting a drop of three-in-one oil on the tip of each, brushing it around with an old tooth brush, they're pretty much protected, halfway through winter. Reapply in a couple of months to be sure.
    #9 Mendel Leisk, Apr 15, 2019
  10. Patrick Wong
    18,210
    6,513
    Kris, since you are planning to buy snow tires and steel wheels, why not buy from tirerack.com ? Call them and ask for a package price.
  11. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    When I was shopping for dedicated snow tires on its own wheels, I thought basic steely is the cheapest. After doing some comparisons, I ended up purchasing tires and wheels package from Discount Tire. It turned out, the least expensive alloy wheels are less expensive than steel wheels after discount and rebate deals they had. I got 4 alloy wheels, 4 Michelline Xice3, installation kit, tires mounted balanced shipping included total after discount and all the rebate for ~$450.
  12. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Given the crazy winter snow storm we had this year I agree. I drove a Honda Odyssey with Blizzaks on it that was just amazing - much better than a 4wd pickup truck with 'snow rated' all weather tires. Subies with snow tires would be fantastic.
  13. cyberpriusII
    1,157
    1,839
    Hyampom
    Thanks again, guys, I have to make some time and call around in the next few days to TireRack and Discount Tire and a couple of other places. Just not feeling up to being put on hold forever. But rather get this nailed down now rather than November...
  14. ETC(SS)
    7,350
    Use the search term "take offs" when searching ebay for steelies (or alloys) for the Subie, and find out what other models use the same tire/wheel size.
    I did this when buying replacment tires for my usta-truck.
    I maintain that you can get a set of OEMs for cheap and mount snows on them.
    Who knows?
    Their TPMS sensors might be more easily reprogrammable too, since "snows" are a Subie kinda thing.
    They just did a 'yuuge' makeover for the 2020 model year Outback and so the "leftover" G5s will be relatively cheaper.
    Good Luck!
