Any other way to check engine oil level besides dipstick without having to change out the oil?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Moses Bruh, Apr 14, 2019.
  1. Moses Bruh
    Moses Bruh Member
    97
    29
    My 2008's dipstick is trash, on a level surface after wiping the dipstick and reinserting and pulling back out, I cannot comfortably gauge the oil level on the dipstick. Car is driving fine but I want to be able to check if its getting low or not.
  2. audiodave
    audiodave Active Member
    800
    272
    US
    That dipstick is your only ticket. Check the oil after it's sat for several hours. Compensate for ground level.
    kenoarto likes this.
  3. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Or buy a new dipstick? Even at dealer prices, they can't be all that ridiculous.
    edthefox5 and kenoarto like this.
  4. dolj
    dolj Senior Member
    8,509
    4,318
    Wellington, New Zealand
    I find it helps to get a good reading by waiting a couple of minutes after wiping the dipstick before reinserting it. It seems that there is a bit of oil dragged up the dipstick tube when you withdraw it and waiting a few minutes allows it to drop back down the tube. I also look at the top side of the dipstick, as the bottom side seems to suffer from oil being dragged along it.
    Hope that helps.
    kenoarto and scona like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    It can be hard to see freshly changed oil on a dipstick. If you still can't tell, after following @dolj's tip, try pulling and wiping the dipstick, wait a minute or two, reinsert the dipstick and then pull it out and lay it on a flat paper towel. The part of the stick with the oil you want to see will soak the paper towel and the rest will, at most, moisten it a little. Should be pretty obvious.
    Once you'd got a few hundred miles on that oil, it'll darken up. All 20 or 30 cars I've had have been like that.
  6. prius_deep
    prius_deep Member
    105
    road
    the oil is way way low, you are reading the splashiness the dipstick is getting. turn off the car take the dipstick out, wipe it off, take it inside your home. wait an hour or two, etc; stick it back in, you will see there is no reading.
  7. bisco
    52,273
    post before and after pics of both sides, we'll read it for you
  8. Mendel Leisk
    41,814
    Need more info, regarding "trash" condition of dipstick.
    kenoarto and audiodave like this.
  9. Patrick Wong
    18,210
    6,511
    If the oil level is below full, one side of the dipstick might read low compared to the other. The low side is the correct side to read. Fill to the full dimple and both sides of the dipstick should read about the same.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    or if you're feeling really frisky, drill a bunch of small holes in the dipstick from the top dimple down to near the tip. Your true oil level will be where the highest hole is filled with oil. One 2007 Prius dipstick from the parts car, one drill press and one 3/32 cobalt steel jobber bit. Poked a hole where each dimple was, one in the ~middle then one in ~middle of those.
    #10 TMR-JWAP, Apr 14, 2019
  11. Mendel Leisk
    41,814
    Huh, kinda like the windshield washer dipstick.
    I don't think I'd could bring myself to do that though. Even with a drill press, I'd be sure to screw up.
    Raytheeagle likes this.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Pull a spare one from the landfill for a test;).
    You’ve got time in your hands:).
    I’m sure it’d turn out fine(y).
    jerrymildred and Mendel Leisk like this.
  13. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    I agree with the OP that the reading is always a bit vague. When I do an oil change and KNOW I've put in the right amount of oil I'll see a big difference from one side of the dipstick to the other. Good tips about pulling it and waiting a while, I'll have to try that.
  14. Mendel Leisk
    41,814
    I did an oil change on our 2010 last Friday, and put in the specd amount, carefully measured with a graduated pitcher. Before start up (oil filter not filled) it was on the top mark, but a day or two later, was about 1/4" lower. I top it up carefully to that upper mark, cus down the road I want to see asap if it starts using. So far nothing though, never had a car this tight.
  15. Moses Bruh
    Moses Bruh Member
    97
    29
    Thanks for all the posts everyone, got real busy after i posted so i just got to read all the posts.
