Sound Deading
Discussion in 'Gen 4 Prius Accessories and Modifications' started by will the engineer, Feb 20, 2019.
  1. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    I used the search function and found nothing...otherwise
    Has anyone purchased any sound deading matts?
    Which ones? Hush matts, dyna matts?
    Also which tools did you end up purchasing with it?
  2. WilDavis
    WilDavis Senior Member
    2,489
    2,153
    49
    I used to have a Mini (van) when I lived in the UK ->1983, and I found the best way to deaden the sound was to use carpet under-lay glued to all the panels, roof, side, door, hood. It took a while to cut everything to shape, but I'm sure these days, tailored kits are available, so have at it, and good luck! ;)
  3. jstevens44
    jstevens44 Junior Member
    29
    Charlotte, NC
    I’ve googled this and there definitely some videos discussing it on earlier gens. I would love to see a 4th gen update to sound deadening. I would love to do this to my 2017 Prius Three.
  4. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    One of the threads on here about increasing the boot/trunk size by removing the foam inserts and spare wheel had some details on sound deadening.
    The bottom line was you line everything with dynamat or similar. In the UK, there's a product that is supposedly better you can find here:
  5. dald
    dald Junior Member
    sgp
    I've recently just did up my doors and wheel wells. I took some pictures. Will post it up when I get the time
    For a DIY sound job, I'd say its ~15% quieter.
    There's less road noise from the tyre but my Yoko blue earths are still noisy as hell.
    It's nice to have heavier and more solid doors to. Because the car is more quiet overall, I'm hearing a lot of plastic rattling coming from the front dash
  6. stewie3128
    stewie3128 Junior Member
    17
    Los Angeles
    2018 Prius
    What brand of mat did you use?
    Francis Polanco likes this.
  7. ice9
    ice9 Active Member
    581
    343
    norfolk va
    2018 Prius
    When you say "~15 % quieter", is that by ear or by noise level measurements?
