I got the dreaded B1826 SRS error code...
Discussion in 'Prius c Technical Discussion' started by PriusCguy, Mar 23, 2019.
  1. PriusCguy
    PriusCguy Junior Member
    33
    Sydney, Nova Scotia
    My airbag light turned on a few weeks ago and ran a scan which gave me the code.
    I got the dealer to pinpoint the issue as this code narrows it down to 3 options.
    I got the most expensive issue of course. It's the wiring harness. They determined it's an open in the wiring harness. The dealer told me that I need this part number:
    821615CL71
    Toyota Canada charges $2200 CAD for the wiring harness. After doing some looking around, I have a question. I notice that part was only used on the '12-'14 Prius C models. I know there really isn't much of a difference on the '15+ models...I mean not enough to change the design of a wiring harness....making me think that it's faulty since it was only used for three years.
    I'm looking for a second hand harness. My question is can someone provide an image or schematic of where part number 821615CL71 is under the drivers seat?
  2. PriusCguy
    33
    Sydney, Nova Scotia
    I just want to see what it looks like so I can describe it to an auto salvage yard.
  3. bisco
    52,404
    could it be rodents? have you looked to see if it can be repaired?
    on the harness, when did they add the charge point under the hood? that might be the difference.
  4. PriusCguy
    33
    Sydney, Nova Scotia
    I wondered the same thing about rodents.. but I think the harness is entirely inside the car. The dealer said that the open could be anywhere and that it would take quite a bit of troubleshooting. I read and heard that replacing this is a ten hour job.
  5. CoolPrius
    CoolPrius Active Member
    218
    290
    86
    Virginia
    2018 Prius c
    When you google that part number it shows up as Wire Floor - Toyota (82161-5CL71). I also wish we could actually see what it looks like because I would want to at least check the plastic electrical connections first (if accessible), maybe reseat them before a full replacement. Of course assuming no sign of rodents like Bisco said.
    Airbag Warning Light Code B1826 | PriusChat
  6. PriusCguy
    33
    Sydney, Nova Scotia
    I ordered it a couple days ago from Sparks Toyota in Myrtle Beach. The fed ex tracking number says it only weighs 8lbs. Toyota Canada should be ashamed they charge $2200+tax for the part. I am getting it for $1075 CAD shipped to Nova Scotia...even with duty it should still be half price.
    Now I need to decide to go to a dealer or a garage to install. Ten hour job.
    Has anyone ever had this part installed? What's involved?
  7. ChapmanF
    18,569
    I think they charge by other characteristics than weight, mostly. :) Some big bulky things are expensive just for the space they take up on ships and in warehouses. Wiring harnesses aren't heavy or bulky, they roll up sort of well, but they're danged intricate.
    You will likely have out the seats, carpet, low interior trim and kick panels, center console, etc. Then it's just a matter of following the harness around, undoing all the connectors (there are pictures in the wiring diagram showing how all the different connector release arrangements work; some are more obvious than others) and undoing all of the really, really irritating little push clips that secure the wire harness in place. (Often that goes more easily if you have some kind of skinny, bent-long-nose pliers to get under the clips and squeeze the squeezy bits, but once you get the hang of one kind of clip, it changes to another kind for the next two feet.)
    Toyota got wise to the needs of material separation when recycling cars, and started bundling a length of aircraft cable in with all the electrical wires, with a loop somewhere in the middle. At a breaker yard somebody can just hook a chain to the loop and pull out the whole wire harness with a good yank from an excavator bucket, instead of having to pay people to pop out a zillion irritating little clips. That's only when you don't plan to keep using the car, though.
    mikey_t, michael.sfo and PriusCguy like this.
  8. Mendel Leisk
    41,925
    Maybe plug in that part number at McGeorge Toyota Parts website. Ditto for anything you're looking for. They don't ship to Canada, but still a good resource.
    You might be able to set up a mail-box just over the border in the States. We have set ups like that here in Vancouver, drive down to Blaine. I haven't done it, but was considering it.
    Huh, $670 (US):
    Toyota Wire Floor 82161-5CL71 | McGeorge Toyota Parts
    Ugh, see it's a long drive to Maine.
    #8 Mendel Leisk, Mar 31, 2019
    PriusCguy likes this.
  9. PriusCguy
    33
    Sydney, Nova Scotia
    Well I had to pay $150 import tax for a grand total of $1225 shipped to my door. Much better than the Canadian price...would've been $2530.
    I'm getting a garage that does full auto service to install it. One mechanic worked at Toyota before...then I just have to get the seats calibrated....or they may get it done. I won't be able to get this done until May as they're very busy.
  10. PriusCguy
    33
    Sydney, Nova Scotia
    The part came in two days ago. It's quite the bundle of wires. Lol. I can't get it installed until May...it's a busy time this time of year with many switching to all season tires.
  11. PriusCguy
    33
    Sydney, Nova Scotia
    So I got the wiring harness installed yesterday at a garage and the light is still on. The former Toyota mechanic did a resistor test which made the light go out. He concluded that it was an airbag issue in the drivers seat. I called the dealer to quote the part and they said there are a few sensors that it could be and that they would have to test each one to find out. I thought my error code specified that it is the drivers seat.
    Can anyone help recommend what I should do next...I'm into this for close to $3000 and it's really starting to piss me off....oh and of course I get my first door ding yesterday while they had it...they are checking security cameras to see who bumped my car.
    mikey_t and Mendel Leisk like this.
  12. CoolPrius
    218
    290
    86
    Virginia
    2018 Prius c
    It sucks they didn't or couldn't test out those seat sensors prior to this but I suppose the next step is identify the bad sensor and replace with new or used.
  13. ChapmanF
    18,569
    For that kind of dough, you might want to access the Repair Manual yourself (more info) and follow the problem-isolation steps on your own ... you learn more, and you're not at the mercy of somebody else's slipshod diagnosis. It really sounds like the dealer in the first instance thought "this kind of problem is very time-consuming to track down, the customer will probably balk at our hourly rate for that, so instead of tracking down the real problem, just quote him the most expensive part it could turn out to be, so he gets the message and goes away and we can do the jobs we enjoy more." Only you, unexpectedly, took them at face value and replaced the expensive part. They would probably be shocked.
    Some of the tests in the manual will involve a milliohm meter: a specialized instrument you probably don't have, even if you have a regular multimeter with an ohm range. Reputable ones from recognized names can be mid-hundreds to $1k or so (the one Toyota recommends, which is quite a nice instrument if you might be running a repair shop, is around $1200). As with almost anything anymore, you can find oodles of no-name cheap ones of completely unknown quality on ebay, some under $100.
    The distinguishing feature you'll notice on a respectable milliohm meter is its four-lead input arrangement, leading to a pair of Kelvin-style test clamps (two leads to each clamp).
    The steps in the manual with milliohm measurements will be for testing the wiring and connectors, but never with the actual airbag connected at the time. For any testing with the airbag in the circuit, you're not looking just at any milliohm meter, but an igniter tester, which is like a low-ohm meter with special circuitry so that even in failure nothing can make it output more than a fixed number of milliamps. Prices on those get right up there comparable to, well, Toyota wire harnesses. :(
    You could probably not pay me enough to take any chance on a no-name ebay igniter tester. But for all tests not involving the live airbag itself, a cheap milliohm meter might be enough.
  14. PriusCguy
    33
    Sydney, Nova Scotia
    Thank you for the replies. As a technician myself, I should have just went right to the sensor. The dealer claimed that there was some intermittent connection when they moved the bundle of wires. Luckily I didn't pay Canadian prices for that wiring harness. I ordered the seat back rest airbag module and should be getting it installed later this week. (Much cheaper option and one hour to install)
    Funny thing today I noticed with my car. My two rear doors won't unlock or lock from my keyfob or the three switches that are part of the car. (Switches from both front doors and the outside switch on the hatch). I think the mechanic may have forgot to connect my rear doors...anyone have any suggestions what may cause this? If two of my power locking mechanisms went at the same time, I am just going to leave it...it's the two rear side doors.
    Thank you. :)
